Hybrid Build Up. Who Knows There Shit. Need Compression N Clearance help
Old Sep 21, 2004 | 10:46 PM
Full Race A6's Avatar
Default Hybrid Build Up. Who Knows There ****. Need Compression N Clearance help
Alright. Ive just found a block thats in my budget for a killer price.
First Ill let you know about my head, its a D16a6 head, fully built all internals but Im worried about clearance and compression with this so that what Ill mention, the head is milled .040 thousand, 1mm oversized titanium valves and running a delta 272 cam (aggressive)
Now the block
D16y7, SRP 9:1 comp pistons, Crower billet rods, balanced and micropolished d16y7 crank, .020 overbore.
Now if you guys would be able to tell me what compression I would be running (estimate ) with a cosmetic head gasket.
Also if you could give me any clearance advise, please dont say clay it, because Im not gonna buy it if theres a chance of slapping
Any other advise appreciated. Car will be boostin 16-18psi daily on TurboEdit
Thanks
Old Sep 21, 2004 | 10:50 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Hybrid Build Up. Who Knows There ****. Need Compression N Clearance help (Full Race A6)
i HIGHLY doubt that you will have valve piston contact. the head i am using is milled the same amount and i am using P29 pistons with RM cam, no contact as long as i keep the cam turning along with the crank.
what happened to your NA build idea?
stan
Old Sep 21, 2004 | 11:00 PM
johnzm's Avatar
i hope you have been reading about the perils of using titanium parts in your head
seems its a very abrasive metal
Old Sep 21, 2004 | 11:10 PM
Default Re: Hybrid Build Up. Who Knows There ****. Need Compression N Clearance help (johnzm)
Still have the high comp project moving quick ****, thats going to be the car I run laps on teh track with
THis boosted Crx is my daily POS
Never heard anything about titanium parts being bad. My springs are also dual titanium
Old Sep 21, 2004 | 11:30 PM
johnzm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race A6 &raquo;</TD></TR><TR><TD CLASS="quote">Still have the high comp project moving quick ****, thats going to be the car I run laps on teh track with
Never heard anything about titanium parts being bad. My springs are also dual titanium</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=973020&page=6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1stGENGSR &raquo;</TD></TR><TR><TD CLASS="quote">titanium doesn't have as high of a Rockwell (hardness) rating as steel, therefore it tends to wear out VERY quickly as compared to steel parts of the same kind.....Take retainers for example, a dual spring setup in a high performance valvetrain can actually wear through Ti retainers in a fraction of the time a typical steel retainer would even start to 'show' signs of wear.
However though it wears down easier, it is not as brittle as steal so it can handle higher lift........Kinda of a ying and yang situation!</TD></TR></TABLE>
Old Sep 22, 2004 | 01:34 AM
biggdogg's Avatar
i`ne been runnin the same portflow retainers in my setups for about 3 years and have had no problems. i even pulled them outta one head and put them in another. titanium ret`s and portflow inner and outter springs. maybe im just lucky
Old Sep 22, 2004 | 01:39 AM
Default Re: Hybrid Build Up. Who Knows There ****. Need Compression N Clearance help (biggdogg)
its cause were up until 6am
free bump for us
Old Sep 22, 2004 | 04:22 AM
crx_88_si's Avatar
piston dimensions?
with know piston dim i can tell u exactly what the cr will be.
Compression Height, (mm) and dish/dome and it's height (mm).
Old Sep 22, 2004 | 04:30 AM
crx_88_si's Avatar
added: also.. so far it looks to be close to 9.1:1 c/r.
I used http://www.knology.net/~jediklc/D.htm
Old Sep 22, 2004 | 09:14 AM
Default Re: (crx_88_si)
hmm wish I had those #'s
as long as Im 9:1-9.5:1 Ill be happy
And obviously dont want **** to slap eachother
Old Sep 22, 2004 | 09:31 AM
crx_88_si's Avatar
Default Re: (Full Race A6)
call srp and ask for the dimensions
Old Sep 22, 2004 | 09:42 AM
Just waiting on the specs from the seller
But still need clearance opinions
Old Sep 23, 2004 | 11:20 PM
this block is defientely mine if I want it, need some help
Honda_Noob42385
Feb 26, 2009 04:52 AM
erebunicrx
Feb 17, 2005 12:50 PM
Full Race A6
Sep 22, 2004 09:34 AM
lazyguy
Dec 10, 2002 07:40 PM
