suspension help
Old Sep 21, 2004 | 05:47 PM
ice11honda's Avatar
Default suspension help
I have a 96 hatch and currently have Koni yellows with ground control coilovers. The ride is good, but my front wheels get shoved into the wheel well hard and way too often. The gap between the wheel well and tires is enough for me to stick my fingers in between. I see others roll this low and not have the same problem as me.
I have been thinking of switching to a better set-up, but not sure what will fix my problem. I was thinking the Tein Flex or Cusco damper. Anyone have thoughts, suggestions, or can relate? I have been battling my suspension for years and really want to eliminate this problem. Help is greatly appreciated.
Old Sep 21, 2004 | 05:52 PM
OpTiX619's Avatar
Default Re: suspension help (ice11honda)
you could take out the plastic that is in your wheel well.....
dan
Old Sep 21, 2004 | 06:00 PM
ice11honda's Avatar
Default Re: suspension help (OpTiX619)
This is worse than rubbing theliner. My wheels are getting slamed into the wheel well. So many time the pinch bar has worn through the plastic lining.
Old Sep 23, 2004 | 06:33 AM
ice11honda's Avatar
bump on some more thoughts and replies.
Old Sep 23, 2004 | 07:12 AM
Jon V's Avatar
Default Re: (ice11honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ice11honda &raquo;</TD></TR><TR><TD CLASS="quote">bump on some more thoughts and replies.</TD></TR></TABLE>
what model car do you have?
My bad (96 Hatch)
I would say to think about getting a front sway bar to stiffen that front suspension up. but that is going to give you a little more understeer so you may want to think about getting a rear sway bar too. Myabe just try and find some SI control arms and get an SI front and rear sway bar. Or maybe you should look in to getting your Koni's revalved (for stronger dampening) and maybe look into getting some stiffer springs.
also you may look in to replacing some of your older more worn out bushings with some new ones (OEM, or Energy, etc)
Just trying to give you some other ideas befor you go off buying a $1000 coilover that probly wouldn't help much anyways.... cough cough ...Tein Flex... cough cough
Old Sep 23, 2004 | 03:43 PM
ice11honda's Avatar
Default Re: (Jon V)
You bring valid points to the table. I've been wondering if switching out the old control arms and bushings would be any help, but never found anyone that could say. My buddy who is great with suspension knowledge is rolling my car today while I roll his. He has Zeal B2 set-up and I love the stiff *** springs it has. The ride is bouncy, but that is what I want. So now I am thinking of buying his 5 month old Zeal set-up, and hopefully the stonger spring rate will help my problem. If not then I will look into swithing out the bushings, then control arms til problem solved. Thx
Old Sep 23, 2004 | 03:50 PM
project_mercy's Avatar
Is it rubbing all the time, or at specific times, like 'when I hit a pothole' or 'when I brake in a straight line' or 'when I take a turn' etc?
Old Sep 23, 2004 | 07:25 PM
ice11honda's Avatar
Default Re: suspension help (project_mercy)
A pothole is when the bad noise happens, when it sounds like the wheels slam into the wheelwell, but it doesn't have to be a big pothole. Okay, here is a good example. The huge metal sheets that are place on the road to cover a hole will make this happen.
As for turns the front tires rub the liner, but not too sharp of a turn will make it happen. It is way too frequent. Too soft up front, but for the ground control's I think my spring rate is 380 up front. My car shouldn't lean so much for as low as it is.
Also there is too much play in my steering wheel. It is not as responsive as it used to be.
deepsouthhybrid
Acura TSX
Nov 21, 2011 02:19 PM
vincent001
22
Dec 23, 2006 01:09 AM
Charbon Sty
Sep 29, 2003 06:55 AM
Adampops
Dec 15, 2001 05:51 PM
