ANy gains with headgasket
Old Sep 21, 2004 | 04:31 PM
ecumatt's Avatar
Default ANy gains with headgasket
Would i see any gains running a thinner headgasket with a bone stock b16a?
Old Sep 21, 2004 | 04:47 PM
johnzm's Avatar
Default Re: ANy gains with headgasket (ecumatt)
25whp
do it.
Old Sep 21, 2004 | 06:23 PM
Y2K Si FBP's Avatar
Default Re: ANy gains with headgasket (johnzm)
prolly 2.5 hp at the crank. heh i'd only do it if u just built a motor..or need to replace the headgasket. not specifically pulling the head just to do a headgasket..not worth it
Old Sep 21, 2004 | 09:48 PM
yeegsr's Avatar
Default Re: ANy gains with headgasket (Y2K Si FBP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K Si FBP &raquo;</TD></TR><TR><TD CLASS="quote">prolly 2.5 hp at the crank. heh i'd only do it if u just built a motor..or need to replace the headgasket. not specifically pulling the head just to do a headgasket..not worth it</TD></TR></TABLE>
wat? thinner headgastket prolly add 2.5 at crank? are you kidding man? for gasket? i thought gasket are classfied for their insulant=meaning preventing high heat temperature transfer from the head to header, of course it wills help but 2.5hp?
nah .....i am not with you on this...
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">25whp
do it.</TD></TR></TABLE>
haha you are BADDDDDDDDDD
Old Sep 21, 2004 | 10:14 PM
SPEEDCORE's Avatar
Default Re: ANy gains with headgasket (yeegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
nah .....i am not with you on this...</TD></TR></TABLE>
Dude... headgasket is different to an exhaust manifold gasket.....
Old Sep 21, 2004 | 10:17 PM
johnzm's Avatar
Default Re: ANy gains with headgasket (SPEEDCORE)
what would u know, your form AUSTRAILA
hehe
sorry if im an *** to the wrong person...
dude your from CALI your supposed to know this ****. i live on the east coast and were like 10 years behind cali. headgasket just keeps oil with oil and water with water. it also seals up the space between the head and block and the thinnner u can makeit the more compression you get. IMO the addition in compression MIGHT be negated by the resulting cam timing i dont have any data to back that up tho
Old Sep 21, 2004 | 10:35 PM
SPEEDCORE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">what would u know, your form AUSTRAILA
Yeah, what would I know..... I'm from Australia, as opposed to form Austraila
Old Sep 21, 2004 | 10:57 PM
johnzm's Avatar
lol owned by typos
Old Sep 22, 2004 | 03:01 AM
OLM-02R's Avatar
hahahahahha
thin headgaskets bumps ur cr a bit...
Old Sep 22, 2004 | 09:05 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPEEDCORE &raquo;</TD></TR><TR><TD CLASS="quote">
Dude... headgasket is different to an exhaust manifold gasket..... </TD></TR></TABLE>
oh my bad man....compression can be raise or drop can also depends on the gasket thinner = raise the compression right?
Old Sep 22, 2004 | 09:52 PM
SPEEDCORE's Avatar
oh my bad man....compression can be raise or drop can also depends on the gasket thinner = raise the compression right?</TD></TR></TABLE>
*nods* Yep.....Thinner = increase in CR
Thicker = decrease in CR
Standard thickness........ no change to CR.....but I'm sure you would have figured that out by now though!
NA JDM GSR
Nov 24, 2006 08:17 PM
WOODman
Jun 6, 2005 04:08 PM
topspeed86
Jan 6, 2005 05:18 PM
fknfast
Mar 1, 2004 07:23 PM
careawholelot
Oct 8, 2003 08:04 PM
