gas in the oil??? what does it mean?
Old Dec 10, 2001 | 11:06 PM
wdyno's Avatar
New User
Default gas in the oil??? what does it mean?
my car doesnt start and and i pulled off the valve cover and i immediately smell plenty of gas.. i drained the oil.. and theres lot of gas in it..... and theres no oil in the coolant.... no gas in coolant either... can anybody tell me whats wrong wit my car??
Old Dec 10, 2001 | 11:18 PM
Cramerox's Avatar
Default Re: gas in the oil??? what does it mean? (wdyno)
Old Dec 11, 2001 | 09:40 AM
stangkilla's Avatar
Default Re: gas in the oil??? what does it mean? (Cramerox)
you got a big problem
Old Dec 11, 2001 | 09:48 AM
gsrapper's Avatar
New User
Default Re: gas in the oil??? what does it mean? (stangkilla)
better take that **** to the shop
Old Dec 11, 2001 | 10:08 AM
rtype11's Avatar
you are running really rich and washing your cylinders, the gas goes right by the rings and mixes with all the oil ruins some sealing compounds and gasket material as well as lowers viscosity of your oil and worn bearings etc etc etc, sure it was really that much, could just be flooded or bad ignition.
Old Dec 11, 2001 | 10:11 AM
MachAF's Avatar
Are you sure its gas in the oil and not water?
sounds like maybe piston ring problems or headgasket.
Is there oil in the cylinders? take out spark plugs and look.
Old Dec 11, 2001 | 10:28 AM
wdyno's Avatar
New User
so it cant be a bent valve? my car doesnt crank up either.... it cranks a bit and just dies.... well... the motor is dead and not moving so i dont think my bearings or anything is damaged... i hope... could it have been detonation? cracked piston? i dont see any oil in the cylinder....
Old Dec 11, 2001 | 11:13 AM
MachAF's Avatar
BAttery's not dead is it?
Make sure each spark plug is getting spark.
Old Dec 11, 2001 | 11:38 AM
wdyno's Avatar
New User
Default Re: gas in the oil??? what does it mean? (machaf)
nope replaced the batttery too, replaced distributor, starter, spark plugs, ecu, and tried to push start it... and tow start it.. when i tow started it...i left it in gear while being towed by another car, heard a grinding sound...
Old Dec 11, 2001 | 05:08 PM
1fastGSR's Avatar
New User
blown head gasket?
Old Dec 11, 2001 | 06:14 PM
JL 74's Avatar
25 Year Member
Are you sure its gas in the oil and not water?.
Good point, I dont have my ChE handbook in front of me to look up solubility of either one, but I would imagine they would mix, especially at high temps.
Old Dec 12, 2001 | 12:01 AM
wdyno's Avatar
New User
Default Re: gas in the oil??? what does it mean? (jl74)
i dont think its the headgasket... cuz theres no oil in the coolant
Old Dec 12, 2001 | 09:53 AM
bigTom's Avatar
could be ur valve seals
Old Dec 12, 2001 | 03:26 PM
1fastGSR's Avatar
New User
that's right
Old Dec 12, 2001 | 04:01 PM
B2FiNiTY's Avatar
Man.. that hurts.
Old Dec 12, 2001 | 04:08 PM
fsarfino's Avatar
Default Re: gas in the oil??? what does it mean? (B2FiNiTY)
did you check for a stuck injector ???
00civiccali
Jul 21, 2008 09:15 PM
don24
Mar 7, 2006 08:34 PM
monicle
Feb 6, 2005 10:14 PM
Layziebtnh055
Apr 12, 2004 10:03 AM
ucb
Apr 24, 2003 01:31 AM
