Help....oil leak
Old Sep 21, 2004 | 03:12 PM
DriveSlowHomie's Avatar
Default Help....oil leak
i have a integra gsr....there seems to be oil leaking from my head...where the cams are right by the vtec solenoid....seems to be from a seal or something...is this normal...easy to fix?...the oil doesnt leak enough to drip but then still gets my block very oily...help please... thanx
Old Sep 21, 2004 | 03:29 PM
Redtail's Avatar
Default Re: Help....oil leak (cmGSR916)
cam shaft oil seal - really common and easy to fix. just get a new seal, (eagle makes some shiny aluminum ones if you're into that sort of thing), take off the valve cover and swap the seals out.
Old Sep 21, 2004 | 03:35 PM
Default Re: Help....oil leak (Redtail)
thank for the info...thats the same things as what str makes correct?
Old Sep 21, 2004 | 03:38 PM
ILOVEGIRLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmGSR916 &raquo;</TD></TR><TR><TD CLASS="quote">thank for the info...thats the same things as what str makes correct?</TD></TR></TABLE>
yes.
Old Sep 22, 2004 | 03:50 AM
JimBlake's Avatar
Default Re: Help....oil leak (ILOVEGIRLS)
Check out this thread...
https://honda-tech.com/zerothread?id=784711
I changed that cam seal, & I had to take off the last cam cap. I also changed 3 seals at the VTEC valves. #12, #14, & # 25 in the picture in that thread. I was never really sure which ones were actually leaking. But all of them were kinda hard so they were due.
mtdineen
17
Oct 30, 2014 06:23 PM
itzyaboyzeem03
Nov 2, 2008 01:47 AM
boomersz
Apr 4, 2007 12:14 PM
JDMisGOOD
12
Nov 12, 2005 09:54 PM
DI9ITAL
Mar 30, 2004 07:36 PM
