Adjusing my clutch cablle.
Old Sep 21, 2004 | 12:05 PM
mykal's Avatar
Default Adjusing my clutch cablle.
I rerouted my clutch cable. I backed off the round **** from the bracket and slid the cable out of the brackets. When I put it back on do I just tighten that **** down as far as I can get it and thats it or is there something else I have to do? Does it self adjust after a few miles?
Old Sep 21, 2004 | 12:17 PM
speed_racer012's Avatar
Default Re: Adjusing my clutch cablle. (mykal)
I'm pretty sure thats all you do. just be carefull tightening it to tight. I broke 2 of those nuts in a week because I did that.
Old Sep 21, 2004 | 12:29 PM
therealciviczc's Avatar
Just pull up lightly on the lever, adjust the nut the entire way down and check the pedal... move according to what type of feel you like, but there is nothing tricky to it if that is what you are essentially asking.
Old Sep 21, 2004 | 12:38 PM
mykal's Avatar
Default Re: (therealciviczc)
Basically, yes thats what I wanted to know. I wasnt sure if i adjust it to where I feel its good or if there were certain specs to make sure of so that it engages and disengages properly. I suppose as long as it goes in gear and doesnt grind, its good.
I also found this and it tells you exactly what to do.
http://www.binghamtonlife.com/...4.jpg
Old Sep 21, 2004 | 06:34 PM
4DRmafia's Avatar
where did u route ur clutch cable to ?
Old Sep 21, 2004 | 06:52 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">where did u route ur clutch cable to ?</TD></TR></TABLE>
Probally underneith the intake manifold
Old Sep 21, 2004 | 06:59 PM
4DRmafia's Avatar
can u do that ? i mean will all the heat burn up the clutch cable ?
Old Sep 21, 2004 | 07:33 PM
MonkeyMagic's Avatar
the heat isn't that intense.. but i did notice it made the pedal effort increase and it also chewed my rubber bushing (the one with the bump that holds the nut in place).
AdRoz
Transmission & Drivetrain
Aug 19, 2009 08:37 PM
andrey320
18
Jan 21, 2008 06:22 AM
stackz
Jan 3, 2007 11:32 AM
g2tegsown
Aug 17, 2006 03:54 AM
veggiemaster
Dec 15, 2003 03:15 PM
