440s + Hondata - turbo = driveable?
I have a turbo with 440cc injectors and hondata 2b tuned. I'm going to be taking my turbo off and was wondering if it would be okay to drive my car for a short period of time until I can get some stock sized injectors to put on along with my factory ecu. Any comments or suggestions? Thanks.
Every car is different, may run a little righ in the upper rpm's (or under heavy load) but should be fine in vacuum or light load.
Great, thanks for the replies. I'm only going to be driving it this way temporarily and will definately not be revving the engine high while in this condition.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">I have 550's in my N/A Honda right now until the turbo goes in. Runs fine, but it has been tuned for these injectors.</TD></TR></TABLE>
Key words: "tuned for these injectors"
Just scale down the injector size in Hondata and you should be okay.
i tried it out after i took out my turbo....precision 580cc's and hondata (turbo tune). It ran fine, but it turned out i was running lean kinda
. My gas milage w/ the stock car was around 150miles/half a tank (highway) and running it non-turbo w/ the hondata and 580's it ran about 175miles/half a tank.
TurboSedan
Jan 14, 2011 07:57 PM
