Location of the CRX Map Sensor?
Old Sep 21, 2004 | 09:14 AM
Ri5e's Avatar
Default Location of the CRX Map Sensor?
I know it's on the firewall but there are 3 vacuum lines going.
Is it the one in the middle?
Because the one on the left, I'm looking at it and it and it's connected a piece of plastic that goes nowhere.
Old Sep 21, 2004 | 09:24 AM
therealciviczc's Avatar
It should have a plug with three wires going in to it and a vacume line going in the bottom with two screws going in the bottom up toward the hood. It says MAP on a little sticker on it. It is sort of shaped similar to an oil pan only much smaller of course.
Edit: Maybe the line goes in the top. I've held about 2000000 of them in the last week and can't remember one of the more obvious traits. Anyway... it says map on it.
Old Sep 21, 2004 | 02:16 PM
Ri5e's Avatar
Default Re: (therealciviczc)
Ok, I found it.
Also, I found that one of the vacuum lines is a dummy vacuum line. It plugs into this plastic piece that connects to nothing..
Charlie Moua
Apr 13, 2012 08:24 PM
stackedhouse
11
Apr 25, 2011 01:26 AM
Fuzzy Rhubarb
Oct 11, 2007 01:01 PM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
Ri5e
Mar 27, 2003 06:18 PM
