FS: Dell Inspiron 8000 laptop 900 Mhz, DVD/CD-RW, 2nd HD, NEW battery 15"
Old Sep 21, 2004 | 08:42 AM
JDubya's Avatar
Default FS: Dell Inspiron 8000 laptop 900 Mhz, DVD/CD-RW, 2nd HD, NEW battery 15"
I'm getting rid of my car so I dont need this laptop anymore. It's got a fresh install of Windows XP Pro with the updates. Here's the info:
Dell Inspiron 8000 Laptop Computer
Pentium III, 900MHz
15" high resolution 1400 x 1280 Resolution Screen,
384MB SD RAM,
2 DIMM expansion slots,
32 MB DDR 4x AGP GeForce2 Video Card
10 GB Hard Drive,
2nd bay with 20GB Removable Hard Drive,
8x DVD Drive 32-4x CD-RW and Floppy Drive
Brand new DELL 66Whr 4460 mAh battery
Microprocessor
Microprocessor type Intel® Mobile Pentium® III or Mobile Celeron™
L1 cache 32 KB (internal)
L2 cache 128 KB or 256 KB
Math coprocessor internal to microprocessor
System Information
System chip set Intel 815e
Data bus width 64 bits
DRAM bus width 64 bits
Microprocessor address bus width 32 bits
Flash EPROM 4 Mb
Graphics bus 64-bit AGP 4X bus
PC Card
CardBus controller Texas Instruments PCI 4450/4451 CardBus controller
PC Card connectors two (supports two Type I or Type II cards or one Type III card)
Cards supported 3.3 V and 5 V
PC Card connector size 68 pins
Data width (maximum) PCMCIA 16 bits
CardBus 32 bits
Memory
Architecture SDRAM
Memory module socket two user-accessible SODIMM sockets
Memory module capacities 64-, 128-, and 256-MB 3.3-V SDRAM SODIMMS
Standard memory 64 MB (non-ECC)
Maximum memory 512 MB (non-ECC)
Memory clock speed 100 MHz
Memory access time CL2 or CL3 (CL2 and CL3 indicate a CAS latency of two and three clocks, respectively.)
Ports and Connectors
Serial 9-pin connector; 16550C-compatible, 16-byte buffer connector
Parallel unidirectional (standard AT), bidirectional, or ECP connector
Video VGA connector
Audio stereo line-in mini connector; microphone-in mini connector; headphone/speakers (line-out) mini connector
PS/2 keyboard/mouse 6-pin mini-DIN connector
USB two USB-compliant connectors
Infrared sensor compatible with both IrDA Standard 1.1 (Fast IR) and IrDA Standard 1.0 (Serial IR)
Docking 200-pin connector for Dell advanced port replicator
S-video TV-out 7-pin mini-DIN connector for S-video, composite video, and S/PDIF (TV/digital audio adapter cable supports composite video and S/PDIF)
Modem/network connectors optional factory-configurable RJ-11 and
RJ-45 ports for mini-PCI modem/network controller
IEEE 1394 4-pin serial connector
Video
Video type 128-bit hardware-accelerated video support
Data bus 4X AGP
Video controller ATI Mobility M4 orNVIDIA GeForce2 Go
Video memory 8 MB (standard), 16 MB, and 32 MB (maximum)
LCD interface LVDS
TV support NTSC or PAL in S-video and composite modes
Audio
Audio controller ESS Technology Maestro-3i
Stereo conversion 16-bit (analog-to-digital and digital-to-analog)
Interfaces:
Internal
PCI bus/AC 97
External
stereo (line-in), microphone-in, headphones/speaker (line-out)
BEST offer gets it. NO lowballers!
Old Sep 21, 2004 | 12:03 PM
TonyStarkz's Avatar
Default Re: FS: Dell Inspiron 8000 laptop 900 Mhz, DVD/CD-RW, 2nd HD, NEW battery 15" (ALL MOTOR LS till 4K)
instead of risking a low ball, why not throw out a rough price
Old Sep 21, 2004 | 12:14 PM
Ant-man's Avatar
Post some photo. I'm in market for "newer" laptop.
----- Antony
Old Sep 22, 2004 | 05:42 AM
JDubya's Avatar
Default Re: FS: Dell Inspiron 8000 laptop 900 Mhz, DVD/CD-RW, 2nd HD, NEW battery 15" (Ant-man)
andyxle
Northwest (Sales)
Aug 31, 2009 09:05 PM
jromulo
Sep 16, 2007 04:55 PM
JDubya
Sep 26, 2004 02:06 PM
