who do i goto, to purchase the homemade rear camber kit?
Old Dec 10, 2001 | 07:55 PM
confucius's Avatar
Default who do i goto, to purchase the homemade rear camber kit?
i need a rear camber kit for my car.
i have the eibach prokit.
i need to know who do i go to the buy the kit which includes two bolts and a couple of washers.
i dont know what size bolt will work, so tahts why im looking for someone who sells it.
thanks..
Old Dec 10, 2001 | 09:31 PM
Gump's Avatar
Default Re: who do i goto, to purchase the homemade rear camber kit? (confucius)
go here http://www.geocities.com/kingmantis81/rearcamber.html
Old Dec 12, 2001 | 11:18 AM
IntegraGSR23's Avatar
Default Re: who do i goto, to purchase the homemade rear camber kit? (xlr8si)
Is a F/R camber kit necessary since you only have pro kits?
Old Dec 12, 2001 | 11:20 AM
junglistgsr's Avatar
its not homemade if you have to buy it.
Old Dec 12, 2001 | 12:02 PM
GTEater's Avatar
Default Re: who do i goto, to purchase the homemade rear camber kit? (junglistgsr)
i think you're refering to the washer method, in which you just have to buy metal washers and insert them somewhere in the rear suspension.......someone on this board has to have a diagram or instructions
Old Dec 12, 2001 | 02:45 PM
5-SpeedFreak's Avatar
New User
Default Re: who do i goto, to purchase the homemade rear camber kit? (GTEater)
Your camber shouldn't be out of whack with the Prokit. What kinda struts do you have?
Old Dec 12, 2001 | 05:45 PM
jdmciviceg's Avatar
New User
Try ingalls.com
Old Dec 12, 2001 | 06:42 PM
MrFatBooty's Avatar
Default Re: who do i goto, to purchase the homemade rear camber kit? (jdmciviceg)
Why do you need a camber kit? Unless you have Koni Yellow shocks set on the lower perch I don't see how your camber can be out of whack.
ingalls.com takes you to "Northrop Grumman Ship Systems Ingalls Operations." Which to say the least, has nothing to do with camber kits. Ingalls Engineering wheel alignment products can be found at ingallseng.com.
Old Dec 12, 2001 | 06:47 PM
dustin's Avatar
Default Re: who do i goto, to purchase the homemade rear camber kit? (MrFatBooty)
Lowering a car /ALWAYS/ affects camber. People that say "a X.X inch drop does not need a camber kit" are just being ignorant. It all comes down to how much extra wear you want on your tires.
You replace the two upper bolts on the compensator arm with longer ones, and put washers inbetween to space the top of the trailing arm out. Just remove the bolts and go to a hardware store (they are metric, so home depot probably will not have them)
Dustin
Old Dec 12, 2001 | 07:26 PM
Total'd GSR's Avatar
New User
Does anybody know if the method described on this site will work on the front?
MrFatBooty's Avatar
Default Re: who do i goto, to purchase the homemade rear camber kit? (dustin)
Of course lowering a car affects camber. You can get away with a small amount of negative camber before tire wear becomes an issue, just be sure to rotate the tires frequently.
The ability to adjust camber is nice, but perhaps money can be more well spent somewhere else if he's not trying to race-prep his car.
Old Dec 12, 2001 | 09:50 PM
ingrate's Avatar
25 Year Member
Default Re: who do i goto, to purchase the homemade rear camber kit? (Tanabe'd GSR)
nope, for the front you need new joints for the upper control arm to fix camber.
jeison
Jun 9, 2006 12:16 PM
fafsa
Apr 6, 2005 03:40 PM
drewbie
13
Jan 6, 2005 03:13 PM
Hatch_00
Jan 11, 2003 10:15 PM
Takeoff
Aug 11, 2002 01:08 PM
