Hamp Oil Filters!
Old Sep 21, 2004 | 06:30 AM
hybrid_vtec's Avatar
Default Hamp Oil Filters!
Are these worth using on a non-vtec engine, since we dont dont have to rely on oil pressure for vtec? I already have a GSR oil pump, but wanted to know if it the extra oil pressure would be beneficial?
Also is there a dealer in San Diego, CA that stocks these?
Old Sep 21, 2004 | 06:57 AM
Doctor CorteZ's Avatar
Default Re: Hamp Oil Filters! (hybrid_vtec)
they dont increase oil pressure.
Old Sep 21, 2004 | 08:40 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Hamp Oil Filters! (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">they dont increase oil pressure.
No? Have you used them? I thought about buying some myself. I heard they are identical to the s2000 oil filters.
Old Sep 21, 2004 | 08:54 AM
Default Re: Hamp Oil Filters! (LSVTEC 91 Civic)
all Honda filters carry the same oil pressure , its impossible to raise it unless you rework the oil pump , IE: pressure release valve...
Old Sep 21, 2004 | 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">all Honda filters carry the same oil pressure , its impossible to raise it unless you rework the oil pump , IE: pressure release valve...
Then what is so special about them then?(Hamp or the S2K filters)
And why does everyone say it increases oil pressure?
Old Sep 21, 2004 | 11:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Then what is so special about them then?</TD></TR></TABLE>
they are green.
And why does everyone say it increases oil pressure?</TD></TR></TABLE>
they've obviously never taken a Bseries oil pump apart , it has its own pressure regulator in it , raising oil pressure is impossible without altering that.
Old Sep 21, 2004 | 01:07 PM
Good Info!
Now...
So someone explain to me whats so good about the S2K oil Filters!
Old Sep 21, 2004 | 03:15 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Good Info!
Now...
So someone explain to me whats so good about the S2K oil Filters!</TD></TR></TABLE>
s2k filters are made in japan
Old Sep 22, 2004 | 05:30 AM
Default Re: Hamp Oil Filters! (ArinX)
So is there nothing special about these filters! Can I just use a Mobil 1 filter and be just as good as any other supposed performance filter!
Old Sep 22, 2004 | 06:48 AM
I also like the K/N filters actually , if you've ever cut one apart and compared to a Honda one you'd see.
Old Sep 22, 2004 | 09:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">I also like the K/N filters actually , if you've ever cut one apart and compared to a Honda one you'd see.</TD></TR></TABLE>
K&N no longer has the synthetic filter element!
Old Sep 22, 2004 | 10:08 AM
SuperSlow's Avatar
Increase in volume will decrease the pressure in the overall system. Careful what you label impossible.
Old Sep 22, 2004 | 10:18 AM
Default Re: Hamp Oil Filters! (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">
Increase in volume will decrease the pressure in the overall system. Careful what you label impossible.</TD></TR></TABLE>
SO what filters do you reccommend!
Old Sep 22, 2004 | 10:19 AM
93lsd's Avatar
instead of spending the money for a hamp i saw somewhere here they cut open a hamp and a s2k and they look the same and both made in japan, s2k all the way
Modified by 93lsd at 2:15 PM 9/23/2004
Old Sep 22, 2004 | 10:23 AM
spaceman's Avatar
the new small version hamp says 5psi oil pressure increase..i use hamp or oem...there is another new oil filter from powerenterpriseusa.net or com not sure,but it has a built in magnet..which is pretty cool
Old Sep 22, 2004 | 10:28 AM
Default Re: (93lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote">instead of spending the money for a hamp i saw somewhere here they cut open a hamp and a s2k and they cool the same and both made in japan, s2k all the way</TD></TR></TABLE>
I did some research and found this yesterday! You are right, they are both made by TOYO ROKO!
Old Sep 22, 2004 | 10:46 AM
slofu's Avatar
Default Re: Hamp Oil Filters! (spaceman)
5psi increase on which side of the filter? basically, a smaller filter, or one with more restrictive filter media will cause a larger pressure drop, increasing pressure in the system before the filter, thereby increasing strain/stress on the engine and pump, causing pumping losses.
many filters with check-valves just bypass the filter media if the pressure gets too high, since it's better to have dirtier oil than not enough oil, so if this is the effect of using a smaller filter, why use one at all?
the best filter is one which filters just good enough to reasonably clean the oil and pass it on. a larger filter will also reduce the pressure drop and associated pumping loss.
Old Sep 23, 2004 | 06:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">SO what filters do you reccommend!</TD></TR></TABLE>
how bout stock.
Old Sep 23, 2004 | 07:20 AM
FairlightRacing's Avatar
Get a Mobil 1. I run the M1-105 and its the best. See this:
http://www.ntpog.org/reviews/f...shtml
By the way if you do go with the oversize 105 instead of the 104 like me you will notice your oil light stays on just a second or so long when you start your car. Its just because of the extra volume it takes an extra second or so to fill the filter and get proper oil pressure. Just something I noticed, it is not bad in any way. These filters kick ***! Cost me $9.99 at Autozone. That plus my 5 quart container of Mobil 1 5W30 for $24.99 lasts me 4000-5000 miles.
Old Sep 23, 2004 | 07:27 AM
n1div's Avatar
Another fairly new entry into the market is the Napa swirl action filter. Might be a gimmick but supposedly, the Nascrap cars use this design in their cars...
Old Sep 23, 2004 | 07:48 AM
StyleTEG's Avatar
Default Re: Hamp Oil Filters! (slofu)
Might one advantage is to keep the oil pressure stable as the oil heats up and thins out?
If it has a pressure release valve it may not INCREASE oil pressure, but it might be able to keep it stable/prevent it from dropping.
Old Sep 23, 2004 | 08:58 PM
Two_K Si's Avatar
Default Re: Hamp Oil Filters! (StyleTEG)
I remember reading that hamp parts were made as a cheaper alternative to expensive OEM Honda parts in other countries. I got this info off of some hamp site from Thailand a few years ago IIRC. One thing i do remember is that hamp products use recycled materials.
Old Sep 24, 2004 | 08:11 AM
Default Re: Hamp Oil Filters! (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">I remember reading that hamp parts were made as a cheaper alternative to expensive OEM Honda parts in other countries. I got this info off of some hamp site from Thailand a few years ago IIRC. One thing i do remember is that hamp products use recycled materials.</TD></TR></TABLE>
Weird never heard that before, but some good info to know! Guess I not buying one of those!
Old Sep 25, 2004 | 03:51 AM
superturboprelude's Avatar
yeah dude just stick wiht teh s2k oil filter they are made in japan !!
Old Sep 27, 2004 | 10:18 AM
Default Re: Hamp Oil Filters! (superjunprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude &raquo;</TD></TR><TR><TD CLASS="quote">yeah dude just stick wiht teh s2k oil filter they are made in japan !!</TD></TR></TABLE>
What up Nam!
Yeah i think Im gonna go with the S2K filter!
Gsir8
Jul 1, 2007 02:12 PM
bonylad
Sep 13, 2006 09:50 AM
Takashi1978
Feb 23, 2006 06:21 AM
boost'dsiR
Jul 20, 2005 02:44 PM
vtec.dc2
Mar 9, 2004 04:41 AM
