97 GSR cams... 3 stage vtec?
Old Sep 20, 2004 | 07:50 PM
91teg's Avatar
Default 97 GSR cams... 3 stage vtec?
i just bought some cams out of a 97gsr there is a small, medium, and large lobe...? Is there a way to tell if these are infact GSR cams? Thanks
Old Sep 20, 2004 | 08:00 PM
garados's Avatar
Default Re: 97 GSR cams... 3 stage vtec? (91teg)
... they're probably gsr or b16 cams if you didn't pay much for them. I hope you have a vtec motor to put them into.
edit: it's not 3 stage vtec. the small and medium lobes are for low-rpm driving to improve swirl in the chamber for improved gas milage. Then, oil pressure builds and allows the rocker arms to lock together and the big cam lobe then controls the valve actuation.
Old Sep 20, 2004 | 08:18 PM
X2BOARD's Avatar
Default Re: 97 GSR cams... 3 stage vtec? (garados)
vtec cams have 3 lobes
ratski
Engine Machining & Assembly
Jan 19, 2019 09:28 PM
D17alltheway
Honda Civic (2001 - 2005)
19
Jun 9, 2008 03:05 PM
Brown-tec
Nov 3, 2005 08:41 AM
