Sounds like valves hitting pistons.....
Old Sep 20, 2004 | 06:47 PM
ToFu-DeLiVeRy's Avatar
Default Sounds like valves hitting pistons.....
Well i finally finished building my b20vtec setup and i got this serious problem now.... when i got the the car started everything was fine and i thought i have finally finished my build...then when the car got to operating temperature there was a tapping sound or knocking sound coming from the engine....i think the valves are hitting the pistons and i dont know why...im using je pistons designed for a b20 vtec setup which is the b20/b16 pistons with a compression ratio of 11.5...do u guys think i need a valve adjustment or do i have to get the valve reliefs shaved????any help will be really grateful cuz im really frustrated and upset!!!
Old Sep 20, 2004 | 06:54 PM
stareatsun's Avatar
check your valve lash. It could be that. Sounds like lite tapping also.
Old Sep 20, 2004 | 06:57 PM
Darkane's Avatar
Default Re: Sounds like valves hitting pistons..... (ToFu-DeLiVeRy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToFu-DeLiVeRy &raquo;</TD></TR><TR><TD CLASS="quote">Well i finally finished building my b20vtec setup and i got this serious problem now.... when i got the the car started everything was fine and i thought i have finally finished my build...then when the car got to operating temperature there was a tapping sound or knocking sound coming from the engine....i think the valves are hitting the pistons and i dont know why...im using je pistons designed for a b20 vtec setup which is the b20/b16 pistons with a compression ratio of 11.5...do u guys think i need a valve adjustment or do i have to get the valve reliefs shaved????any help will be really grateful cuz im really frustrated and upset!!! </TD></TR></TABLE>
I really highly doubt your valves will hit on the secondary lobes (pre-vtec). In VTEC thats the different story, but at idle The hugest cams wont hit the pistons (vtec anyways)
Rhythm
Mar 19, 2006 07:33 PM
ToFu-DeLiVeRy
11
Nov 21, 2004 07:31 PM
ToFu-DeLiVeRy
Sep 24, 2004 05:03 AM
ToFu-DeLiVeRy
Sep 20, 2004 07:19 PM
accord19
Mar 12, 2004 04:15 AM
