Is it easy replacing the 194 bulbs behind the cluster???
Old Dec 10, 2001 | 06:16 PM
RHGSR01's Avatar
New User
Default Is it easy replacing the 194 bulbs behind the cluster???
I want to replace the 194 bulbs behind the cluster to a red bulb. Just wanted to know if the the process of taking the whole cluster out and getting to the bulb is easy. any suggestions and tips??? appreciated ya
Old Dec 10, 2001 | 06:20 PM
MrBite's Avatar
Default Re: Is it easy replacing the 194 bulbs behind the cluster??? (RHGSR01)
Taking out the cluster is quite easy, a bunch of screws...but there are some plastic clips holding the plastic bezel (is that the right word?) in, be careful not to break them. Never changed the lights, but I assume it's quite easy from the looks of the back of a CRV cluster.
Old Dec 10, 2001 | 06:29 PM
B20LS-T's Avatar
New User
Default Re: Is it easy replacing the 194 bulbs behind the cluster??? (MrBite)
Assuming you have a third generation integra, there are two screws on the top of the cluster bezel, remove those. Then carefully pull the bezel out and behind it you will find one screw on each side of the cluster and one on the top, remove those, then pull the cluster out, and there are three bulbs that you replace. You only need to replace the big ones, one on each side and in the middle, just turn the black **** looking thing, and it will pop out! later!
Old Dec 10, 2001 | 11:49 PM
Cramerox's Avatar
Default Re: Is it easy replacing the 194 bulbs behind the cluster??? (Turismo79)
i did the same thing.. word of advice tho- becareful the main board has those copper film which is to complete the circuit. mess those up and you might damage something. this was posted few days ago.
http://pegasus.cc.ucf.edu/~ckh66095/liteup.jpg
[Modified by Cramerox, 12:50 AM 12/11/2001]
Old Dec 11, 2001 | 01:40 AM
B2FiNiTY's Avatar
Default Re: Is it easy replacing the 194 bulbs behind the cluster??? (Cramerox)
That cluster looks burning hot. Whoa
Old Dec 11, 2001 | 07:46 AM
JumbosGS-R's Avatar
New User
Default Re: Is it easy replacing the 194 bulbs behind the cluster??? (Fuzznuts)
Everybody likes my gauges I guess. LOL. I have some more pics if any body needs em. As for taking out the bezel and cluster to get the bulbs, if it takes you more then 20 mins....then go get help....b/c it's easy!
igorka_91
May 7, 2009 11:00 AM
Mires
Feb 23, 2004 07:56 PM
J337_UNIT
Apr 23, 2003 04:11 PM
Yyz
Aug 13, 2001 07:12 AM
