need help distr. cap rotor
Start off by checking that you have correctly gapped all the spark plugs and you are using the correct ones for your application.
Did you touch your TB cable?
Modified by KayOs at 4:31 PM 9/21/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">Did you replace the plug wires to the correct spots?</TD></TR></TABLE>
This is exactly what I'd look at first.
Then I'd take the cap off and look and see if the rotor is still in place and the screw is correctly tightened.
I've had some crazy experiences with cap's and rotor's. Not with the R but my Nissans, and while the idle was also abnormal it actually improved till it just died one day. Turned out to be a faulty brand new cap.
If everything was fine Before the "tune up" go back and check and recheck Everything you just did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">most likely wrong plug order
firing order is 1,3,4,2</TD></TR></TABLE>
This is what i would presume is going on! Have you ever changed these things before?
if you haven't done so in a while - change your distributor cap, rotor button, plug wires, and plugs
Black R
Apr 22, 2006 07:02 AM
