What technical manual do you use for reference when performing repair work on your Accord?
I think Helms is the name of the people who make the manual you are looking for.
I can't direct you as to where to find one though.
I use Haynes(sp?). It works fine for me...and i've put a new clutch/flywheel as well as a few other small things in the engine and it was right on key.
If you are just changing oil and routine **** then haynes is fine. If you are doing anything more, Helms is the bible.
The Helms manual is definitely the one you want. It is pretty much the Honda manual. Try http://www.helminc.com
yep helmsinc.com is it. hope you got some extra cash cause they are expensive! but thats what the techs at the honda dealerships use.
