New to Honda world needs help!
Old Dec 10, 2001 | 04:04 PM
Ltech's Avatar
Default New to Honda world needs help!
I just total my 2k celica gts last week. Now I'm going to buy a Crx and planning to drop a b16a or B18c in it. The Crx i'm getting is a HF. Will i have any problem? I heard that the CRX si will fit right in with B16a engine. What other step i need to take? I'm getting the car tomorrow. Please help. Thank you very much.
jason phan
Old Dec 10, 2001 | 04:16 PM
EP3_05's Avatar
Default Re: New to Honda world needs help! (Ltech)
Ok, since you are getting an hf the wiring will be easier than if you had a dx. You only will have to wire up VTEC solenoid, VTEC oil pressure, secondary O2 sensor(if necessary), and the knock sensor. You will need a mount kit... http://www.hasport.com or http://www.hcpengineering.com You will need to modify the shift linkage or buy one from hasport or hcp. There are some other minor mods that need to be done but overall it is more difficult than a ZC swap but more rewarding from what I hear. I am in the midst of doing a b16 swap into my 4dr. Hasport has some good info on their website about the install.
This is a good site too: http://b16a.honda-perf.org/theswap.html
Good Luck
[Modified by 91civic, 1:24 AM 12/11/2001]
Old Dec 10, 2001 | 04:32 PM
big pete's Avatar
Default Re: New to Honda world needs help! (91civic)
no matter what your going to need a mount kit, modify your harness, shiftlinkage and you will also need dx or si knuckles...i have a b16 in my hf and the thing hauls ***....hf is the lightest model...good luck with your swap
Old Dec 10, 2001 | 04:35 PM
big pete's Avatar
Default Re: New to Honda world needs help! (big pete)
oh yah by the way the hf has a wire for the ecu that goes into pin b11...do not use it for the b16 it will make your ecu throw a code 6(ect sensor)
Old Dec 10, 2001 | 04:37 PM
EP3_05's Avatar
Thanks for that info big pete. I completely forgot about the different knuckles on the hf and I never knew about the wire in the b11 slot on the ecu. Thanks.
Old Dec 11, 2001 | 05:45 AM
Ltech's Avatar
Thanz for all your help. If there is anything else let me know. And I don't miss my celica at all.
wid326
Oct 4, 2004 10:36 AM
uNbrokeN
Feb 28, 2004 07:33 PM
trexb16
Nov 5, 2003 03:16 AM
jdmed8
Aug 17, 2002 08:43 PM
