rc injector leaking gas??? help
Old Sep 20, 2004 | 11:09 AM
ls-r civic's Avatar
Default rc injector leaking gas??? help
Well, the other day my injector started leaking gas from the seal between the rubber o ring and the injector itself, i checked it and i am almost 100 percent sure that is because the rubber washer that goes between the manifold and the injector was broken. the question i have is where can i get a replacement for this?? I have rc 310 injectors and they came with a set of aftermarket washers so the stock ones no longer fit. Any help you can give me would be greatly appreciated.
Old Sep 20, 2004 | 12:38 PM
-faded-'s Avatar
Default Re: rc injector leaking gas??? help (ls-r civic)
im pretty sure oem ones will fit. are you able to call RC and see what will work?
Old Sep 20, 2004 | 03:44 PM
asubennett's Avatar
Default Re: rc injector leaking gas??? help (hybridlsR)
OEM lower injector O-rings will work. I had a RC O-ring fail on me after a year of use as well.
I replaced all four of them with OEM rings and all is fine and dandy.
Old Sep 26, 2004 | 05:57 PM
ls-r civic's Avatar
Default Re: rc injector leaking gas??? help (asubennett)
well i replaced the o ring today and started it up and it is now only leaking a slight bit of gas, anybody got any ideas on why this is.
Old Sep 26, 2004 | 08:25 PM
ls-r civic's Avatar
bump let me get some info guys
Old Sep 26, 2004 | 08:35 PM
eyeamvic's Avatar
Isn't there an o-ring on the injector also? A much smaller one. Just a suggestion, I've had one leak on one of mine before.
Old Sep 27, 2004 | 04:25 AM
asubennett's Avatar
Default Re: rc injector leaking gas??? help (eyeamvic)
Yes there is an injector lower o-ring and there is a larger manifold o-ring and there are the O rings on top of the injectors that seal them into the fuel rail. THe large thick one rests in the manifold and the smaller ones are on the tips of the injectors. Did you pinch the smaller O-ring on the injector when you pushed it into the fuel rail?
Old Sep 27, 2004 | 06:44 AM
H22JEFFREY's Avatar
oem fit that happened to my injectors when i changed my 310cc to 440cc my o ring washer broke
Old Sep 27, 2004 | 11:44 AM
ls-r civic's Avatar
Default Re: rc injector leaking gas??? help (hybridvisionz)
just for clarification, i have one think o ring that sits int he manifold, and another small green o ring that is on the top of the injector where it goes into the fuel rail, please explain what you mean by pinching the injector where it goes into the fuel rail. Another question, is there supposed to be two o rings at the bottom of the injector where it goes into the manifold.
Old Sep 27, 2004 | 05:36 PM
ls-r civic's Avatar
bump for info
Old Sep 28, 2004 | 04:46 AM
asubennett's Avatar
That green o-ring is the one that has failed before on an RC injector for me. IT cracked and split. But also if you are not careful when installing the injector into the fuel rail, that green o-ring can get pinched so that it won't seal.
Old Sep 28, 2004 | 08:25 AM
AllMotoRex's Avatar
also make sure not to overtighten them down or the O ring will come out of placement and cause you to have a leak.
Old Sep 28, 2004 | 08:30 AM
ls-r civic's Avatar
Default Re: rc injector leaking gas??? help (AllMotoRex)
the gas looks like it is coming from where the injector enters the manifold, i may have overtightened, would that effect the manifold o rings seal. thanks guys for all the help so far.
Old Sep 28, 2004 | 09:24 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-r civic &raquo;</TD></TR><TR><TD CLASS="quote">the gas looks like it is coming from where the injector enters the manifold</TD></TR></TABLE>
The injector cannot leak from from that location, unless the injector itself has a crack in the housing. That seal is a grommet (not an o-ring) to seal the manifold from vacuum leaks and position the injector, and that's all it does.
Look to the small o-rings for leaks or somewhere else on the fuel rail (ie: return regulator, feed-end banjo, etc.).
Apply a small amount of oil to the o-rings before installing the rail onto the injectors or vice versa, injectors into the rail.
Old Sep 28, 2004 | 01:36 PM
ls-r civic's Avatar
Default Re: rc injector leaking gas??? help (IN VTEC)
thanks IN VTEC and everyone else for the info, i am going to see what i can do today and get back to you guys. thanks again.
Old Sep 28, 2004 | 03:10 PM
ls-r civic's Avatar
just got done checking the top injector o rings and sure enough two of them were totally ripped up. Does anyone know where i can get an extra set of them. I am talking about the little green ones at the top of the injector that go into the fuel rail. thanks again for the help so far.
Old Sep 28, 2004 | 04:06 PM
ls-r civic's Avatar
bump
Old Sep 28, 2004 | 04:32 PM
aut0tek's Avatar
ACE Hardware has them. just go in there with an old one that is good and match the size. I had exact same problem... I don't anymore. ;-) They're less than a dollar btw.
Ratliff
Old Sep 28, 2004 | 08:13 PM
ls-r civic's Avatar
Default Re: rc injector leaking gas??? help (aut0tek)
thanks i will let you guys know if i run into any other problems.
Old Sep 28, 2004 | 08:59 PM
mattcivic's Avatar
i had the same problem i went and used my oem rings worked way better than those green things. i had a buddy start leaking gas 2 we changed his to oema dn they worked great too.
Old Sep 29, 2004 | 03:10 PM
ls-r civic's Avatar
Default Re: rc injector leaking gas??? help (mattcivic)
changed the injector o rings today with ones i got from a local parts shop, bolted everything up and no more gas leakage. ls vtec runnin strong again. thanks to all that have given input.
turbohatch96y7
Jun 14, 2012 08:34 PM
Toanz
Apr 28, 2008 03:22 PM
pubestripe
Aug 16, 2006 09:03 PM
lilxvtecxpwr
Feb 6, 2003 04:16 AM
