first time timing belt change
Old Sep 20, 2004 | 10:36 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default first time timing belt change
i searched but didnt find what i was lookin for, i was just wondering what parts i should change and i heard that u could buy a neaprean belt or something like that? and if it is better than stock? cuz im planing on puting my skunk2 cam gears at the same time
thanks for your help
Old Sep 20, 2004 | 10:59 AM
matix's Avatar
Default Re: first time timing belt change (raylude)
Do the water pump, balancer shaft seal, auto to manual tensioner. Seals are optional but if they are leaking replace them.
Old Sep 20, 2004 | 11:11 AM
raylude's Avatar
Default Re: first time timing belt change (matix)
thanks for the info. but should i just use factory parts or look for a stronger timing belt?
Old Sep 20, 2004 | 11:34 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
replace all the seals, more than likely they will leak after you replace your timing belt if you choose not to
Old Sep 20, 2004 | 12:32 PM
revlimitx04's Avatar
Default Re: first time timing belt change (MugenHonda)
Ive got the same situation, when you say seals do you mean Tensioner seals...
Could you just give a list of the things you have to do when you hit the 105kmi mark.
Timing Belt
Balancer Shaft Belt
New Auto Tensioners (if not manual convo)
Inspect the Waterpump (how can u tell if the waterpump is bad?)
I thought that is all i needed to do.
Please add on if anything else needs to be done.
Old Sep 20, 2004 | 01:07 PM
matix's Avatar
Default Re: first time timing belt change (revlimitx04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info. but should i just use factory parts or look for a stronger timing belt?</TD></TR></TABLE>
Yea use oem seals and water pump, and if you can find a stronger belt go for it. Ive been looking and havnt found one yet.
Old Sep 20, 2004 | 05:44 PM
typemismatch's Avatar
Honda owns me
AEM makes one, however, it is insanly expensive ($160+), whereas the stock replacement is like $60
Old Sep 20, 2004 | 05:48 PM
h22 civic's Avatar
Default Re: first time timing belt change (typemismatch)
power enterprises and greddy make them see camp1320 for em thats where i got mine
Old Sep 20, 2004 | 07:15 PM
matix's Avatar
Default Re: first time timing belt change (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">power enterprises and greddy make them see camp1320 for em thats where i got mine </TD></TR></TABLE>
Wich one do you prefer. Also how much i might as well get stronger belt on their now being im gonna put some skunk stage 2's in my car soon.I would like the feeling of added security on my valvetrain.
Old Sep 20, 2004 | 07:58 PM
raylude's Avatar
yeah same here. and when matix said go from auto to manual how do u do that dont the fith gens just got auto tensioners?
Old Sep 20, 2004 | 09:16 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">yeah same here. and when matix said go from auto to manual how do u do that dont the fith gens just got auto tensioners?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=549516
you can use the manual tensioner on 5th gens as well.
Old Sep 21, 2004 | 11:27 AM
raylude's Avatar
Default Re: first time timing belt change (SKDRCR)
thanks i think ill try that
f20beme
Apr 8, 2015 07:47 PM
professorman
Mar 27, 2009 02:02 PM
rasta420
Dec 21, 2008 09:52 PM
blue32
Jun 1, 2005 02:10 PM
