CRX GSR swap check list
Sunday. I plan to do my swap. I'm trying to complete a list of everything I have and I'd like for you folks to look it over and make sure I have everything I need.
The CRX is an '89 HF.
The engine is an OBD1 '95 GSR with low miles.
Starting at the wheels and moving up here's my list.
'90-93 Integra knuckles & brake swap
'95 GSR axles and intermediate shaft
'95 GSR axles seals for in the trans
'93 GSR Cable trans
Hasport shift linkage
'89 HF speedo sender
'95 backup switch
'93 GSR cable throw out bearing
'95 clutch and pressure plate
'89 HF clutch cable
CTR flywheel
'95 GSR engine with all sensors
GSR header
GSR cat
aftermarket CRX exhaust
'95 GSR engine harness
'?? CRX HF engine harness (so I can keep the old one stock)
'95 P72 computer
Jumper harness obd(0) - obd1
OBD2 Accord O2 sensor
HASport engine mounts
prelude airbox hose & '95 GSR hose whichever fits best
B18A timing belt side mount
B18A trans mount
B18A rad hose & GSR rad hose (trim to fit)
'95 GSR throttle cable or '89 HF (which one do I need?)
Things I know I need:
CRX Si airbox
'91 CRX Ebrake cables
Things I'm not sure of:
What throttle cable?
What fuel line?
What fuel pump?
Is there anything my list is missing?
Modified by JohnnieChimpo at 7:52 PM 9/20/2004
'93 GSR Cable trans
'95 backup switch
'89 HF clutch cable
CTR flywheel
GSR header
GSR cat
'95 P72 computer
B18A trans mount
CRX Si airbox
What fuel line?
What fuel pump?
Check Ryan's site pretty good info http://www.geocities.com/droppedcrxsi/
things I did not see on your list.
4 wire O2 sensor.
regarding the exhaust. I don't think the stock exhaust manifold and cat will bolt up to the CRX exhaust. It probably will be a little short.
rear trans. mount?
I used a 95 GSR throttle cable and was fine
4 wire O2 sensor.
rear trans. mount?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">link to my site, it has a parts list and how to for the obd1 gsr
Ryan
EDIT: Vee and I posted at the same time!!!</TD></TR></TABLE>
ha ha beat you to your own link. 'sup Ryan. got my car started and seems all finished. Time to call the REF for that sticker !!
Ryan
'90-93 Integra knuckles & brake swap-just use the rear disc conversion, the fronts arent worth it just get cross-drilled slotted up front with hawk pads
'95 GSR engine harness-- you will modify your stock harness of your car to work with that motor
mounts--hasport b-series
B18A rad hose & GSR rad hose (trim to fit)-lower is fine. upper, what i did was cut about an inch and a 1/2 of my stock hose to build up my diameter of the outlet to the radiator then i trimmed the 90-93 ls integra hose to fit over the stock hose and radiator outlet
'95 GSR throttle cable or '89 HF (which one do I need?)-gsr throttle cable
CRX Si airbox-- as far as air box i found the best is to get a skunk2 intake manifold or type r integra first to simplify the throttle cable deal and intake piping then use a crx box with integra tube chopped down or a modified cheap cold air intake(if your not going to a ref) (if going to the ref you need the exact airbox for that motor you are using, make it work)
'91 CRX Ebrake cables--make sure theyre si 90-91 i just rerouted my integra cables because im cheap
What throttle cable?--use the gsr throttle cable
What fuel line?--stock is fine
What fuel pump?--stock is fine
Thanks for your input.
I have to use the Integra front brakes because I have an HF. My HF knuckles won't fit B series axles.
I picked up a CRX Si actually a Civic Ex airbox yesterday because it looks stock and it has a 3 inch outlet unlike the HF which is tiny.
JohnnieChimpo
16
Mar 18, 2004 12:53 PM
