BOTI SEPT 18-19 RAN MY BEST ET AND TOOK 2ND PLACE
I RAN MY PERSONAL BEST IN THE STREET PERFORMANCE CLASS
CONGRATS TO VICHAY AT CC IMPORTS WITH THE WIN 11.94XX @ 114.XX
-I RAN TWO 12.04'S PRIOR TO MY 12.038
CAR 90 CRX MILD B20VTEC SETUP 89MMX84 BORE 12-5-1 JE'S SKUNK-2
MANIFOLD STOCK B16A THROTTLE BODY RS CAMS SPRING ECT.
JDM 98 ITR TRANS HAS SPORT CONVERSION KIT,ACT CLUTCH AND FLYWHEEL
SUSPENTION ADVANCE DESIGHN FULLY ADJUSTABLE SHOCKS AND COIL OVERS.
FULL INTERIOR DRIVERS SEAT FORWARD INSURED AND REGISTERED
RT .554
60' 1.600
330. 4.857
1/8. 7.598
MPH. 89.01
1000. 10.002
1/4 12.038
MPH 112.54
RT .554
60' 1.600
330. 4.857
1/8. 7.598
MPH. 89.01
1000. 10.002
1/4 12.038
MPH 112.54
congrats man i need to get a hold of you about building a b20 block and some head work
-PRO/STEET I THINK BISI DID 10.1@ 137XXX
-S/P VICHAY BUN TOOK 1ST W/ 11.9 @ 114XX
- HIS BEST ET DURRING ELIMINATIONS WAS 11.6 @ 116.XX
-MAX HA RAN 11.5XX @ 115.XX DURRING TIME TRIALS, I RAN MAX IN THE SEMI'S AND HE MISSED A GEAR I THINK, I GOT LUCKY
LAST RUN I RAN 12.044 @ 112.44 THE WINNER RAN 11.9XX @ 114.XX
BOTH CARS ARE FROM MICHIGAN CAME FROM THE SAME SHOP CC-IMPORTS
OF HOLLAND MI..
Modified by allmotorb20vtec at 1:54 PM 9/20/2004
OF HOLLAND MI..
con grad Siv for 2nd and took max out..i was getting nervous ..siv should hit 11's this friday
i won the s/p class w/personal best 11.6@115mph in an old 86 crx
bisi won the pro's class
Modified by B20vtec86crx at 11:50 PM 9/20/2004
was there full 8 car fields for street performance and pro all motor??
what about street comp, any news?
whoever ran 11.60's is cookin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorb20vtec »</TD></TR><TR><TD CLASS="quote"> I RAN MAX IN THE SEMI'S AND HE MISSED A GEAR I THINK, I GOT LUCKY
Modified by allmotorb20vtec at 1:54 PM 9/20/2004</TD></TR></TABLE>
congrats on your run, I ran a 13.5.... I missed 3rd and gear like 5 times, and just gave up.. I was pissed, from a previous run of 11.54@116.. hitting the rev limiter waay before the quarter mile. my car felt like it was hitting a parachute before the traps.. i gave it away.. my fault.. it will never happen again.
RT .554
60' 1.600
330. 4.857
1/8. 7.598
MPH. 89.01
1000. 10.002
1/4 12.038
MPH 112.54</TD></TR></TABLE>
Nice! What slicks are you running? My best 60's to date are 1.7's with 23x8x13's.
RT .554
60' 1.600
330. 4.857
1/8. 7.598
MPH. 89.01
1000. 10.002
1/4 12.038
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorb20vtec »</TD></TR><TR><TD CLASS="quote">i run 23x8x13's M&H slicks at 7.0 psi thanks John at m&h......</TD></TR></TABLE>
John i'm going to need a set of those tooo!!
im not sure the md dyno says i only made 192.3 whp @ 128 lbs of tq
i think i should be doing 210@ 140+ lb/tq if i were to guess... cars weight 1950 w/me in it.
Good Stuff man...Car looks great.
I ended up hitting a 11.99 the next tuesday at test and tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorb20vtec »</TD></TR><TR><TD CLASS="quote">im not sure the md dyno says i only made 192.3 whp @ 128 lbs of tq
i think i should be doing 210@ 140+ lb/tq if i were to guess... cars weight 1950 w/me in it.</TD></TR></TABLE>
Your making between 215-220whp ona Dynojet.
nice 11's must feel great
im still @ 12'0s untill today (crossing my fingers)
Modified by allmotorb20vtec at 11:37 AM 9/29/2004
Nadda, just dialed in my 60ft...I was ona new tire\trans setup that weekend with no testing.
93LSivic
Dec 3, 2004 05:45 PM
