Importparts.com - DRAG Turbo Kit Blowout - $300 OFF!!!!
Check the applications here:
http://www.importparts.com/sho...id=15
Place your order online to get your Honda-Tech $300.00 discount. Use discount code HT-DRAG0904 to get your discount. Let me know if you have any questions.
Modified by ben@importparts.com at 11:07 AM 9/20/2004
damn, thats a good deal. i have about $2100 right now. it includes the intercooler, right? hey, im going to IM you. keep in touch. im serious about ordering one.
DRAG kits come complete with the following:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/ polished cast aluminum end tanks
Blitz blow-off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Boost dependent FMU fuel regulator
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
I'll hold the deal for you. Check your PM.
Oil return assembly
Ben Huynh
Sep 14, 2004 02:53 PM
Double 06
Jul 10, 2002 01:35 PM
