bad squeaking noise
Old Sep 20, 2004 | 08:08 AM
89 exi nut's Avatar
Default 1989 exi bad squeaking noise
my 89 exi 2 door has started to squeak in the front when i turn my wheels .It seems to be worst when the steering is in the middle position and i just barely turn the wheels from side to side . I greased everything visible and the noise is still there. It seems to be worst when i come back from a long ride. It sounds like dry rubber meeting metal...it's very anoying... squeak squeak squeak ...and it's driving me NUTS!!! Has anyone had this problem??
Modified by 89 exi nut at 11:05 AM 9/20/2004
Old Sep 20, 2004 | 03:00 PM
drkshdw107's Avatar
Default Re: 1989 exi bad squeaking noise (89 exi nut)
check your upper and lower ball joints...if you dont know how...try jacking up your car in the front by the lower control arms...take a long pry bar under the tire about 3/4 of the way up the pry bar and pull up and down...you will feel the movement if your ball joints are bad...if there is movement...replace the bad ball joints...uppers are easy...you'll have fun with the lowers though...
Old Sep 21, 2004 | 04:34 AM
89 exi nut's Avatar
Default Re: 1989 exi bad squeaking noise (drkshdw107)
I changed the upper and lower (yes i had fun)ball joints about 3 month ago and there is no free play at all . The only free play i get is from the inner tie rod on the driver side. Will try to regrease everything later today cause this is driving me insane!!!!
Old Sep 21, 2004 | 04:19 PM
89 exi nut's Avatar
You where right "drkshdw107" about checking the balljoints cause one of them where dry !!! No loose at all just no grease. At last no more squeak squeak squeak... Thanx for the tip
SharkEg
Suspension & Brakes
Jun 17, 2012 05:01 PM
1badcrx
May 13, 2011 09:05 PM
aZnAcCoRd02
May 3, 2006 10:36 PM
traitorzxiong
Dec 1, 2005 06:44 PM
rudeman85
Oct 27, 2004 02:52 PM
