bad resistor box?
Old Sep 20, 2004 | 07:28 AM
iwhichisme's Avatar
Default bad resistor box?
hey ive just swapped a b16a into a 91 si, but for some reason only one cylinder seems to be firing. I was wandering what the symptoms are for a bad resister box. Or if not the resister box, what would be causing this to happen. also What is the the proper way to test a distributor for spark? any help is appreciatted!
tia,
chaz
Old Sep 20, 2004 | 07:30 AM
JoshDM's Avatar
Default Re: bad resistor box? (iwhichisme)
there are no symptoms, if the box doesn't work than it was wired wrong.
THEY DO NOT GO BAD!
Old Sep 20, 2004 | 07:37 AM
iwhichisme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">hey ive just swapped a b16a into a 91 si, but for some reason only one cylinder seems to be firing. I was wandering what the symptoms are for a bad resister box. Or if not the resister box, what would be causing this to happen. also What is the the proper way to test a distributor for spark? any help is appreciatted!
tia,
chaz</TD></TR></TABLE>
Old Oct 14, 2004 | 07:04 PM
turboteg2nv's Avatar
bringing this back, can resistor boxes go bad?? my car won't start after turbo install and all trouble-shooting leads to injectors not firing....why?!?!!!!
Old Oct 14, 2004 | 07:31 PM
blah13's Avatar
Default Re: bad resistor box? (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote">bringing this back, can resistor boxes go bad?? my car won't start after turbo install and all trouble-shooting leads to injectors not firing....why?!?!!!! </TD></TR></TABLE>
You know, I had the same thing happen when I tried converting my dx to mpfi, injectors had power but were getting so signal and wouldnt fire, I tried 2 diff boxes but nothing...i just left it as a bad ecu and had to convert everything back.....worst part is its an auto and damn ps9's are hard to come by.
So basicalyl I dont think they can "go bad" as joshDM said before.
Old Oct 14, 2004 | 09:06 PM
Default Re: bad resistor box? (blah13)
I already replaced the ECU, it's a stick though. still not starting...grrrr
Old Oct 14, 2004 | 09:51 PM
RC_SKUBY's Avatar
Id double check all your wiring again that is prob the problem, does it throw any codes?
Old Oct 16, 2004 | 05:55 PM
Default Re: bad resistor box? (skuby_do)
quadruple checked wiring on EVERYTHING times 3. everything is perfect. Not throwing any codes, either
What's wrong with my poor Teg?!
Old Oct 16, 2004 | 11:52 PM
CRX_1.8T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshDM &raquo;</TD></TR><TR><TD CLASS="quote">there are no symptoms, if the box doesn't work than it was wired wrong.
THEY DO NOT GO BAD!</TD></TR></TABLE>
like he ^ said; it is like on/off switch, no in between.
Old Oct 17, 2004 | 12:58 AM
2point2's Avatar
Default Re: bad resistor box? (CRX_1.8T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">like he ^ said; it is like on/off switch, no in between.</TD></TR></TABLE>
yeah.. all the wires are tied into each other..
maybe you just didn't bush the injector clips down all the way..??? (i did that once ) or something stupid like firing order..
are you sure that only 1 cylinder is firing? or is this just a guess?
Old Oct 17, 2004 | 09:50 AM
Default Re: bad resistor box? (2point2)
bump for an answer to my ?
91SiRHatch
Jan 15, 2005 09:09 PM
chbtek6
Dec 17, 2003 05:47 PM
Vtec92Civic
Jul 12, 2003 09:09 PM
