Weight Loss!!!
Old Dec 10, 2001 | 02:34 PM
98Psi ITR's Avatar
Default Weight Loss!!!
What is everyone doing to lose weight on the ITR? I'm trying to bring the weight down and am looking for some proven tips.
Old Dec 10, 2001 | 02:35 PM
Type Goch's Avatar
New User
Default Re: Weight Loss!!! (98Psi ITR)
what have you done so far?
Old Dec 10, 2001 | 02:44 PM
98Psi ITR's Avatar
Default Re: Weight Loss!!! (Type Goch)
besides losing 10lbs myself ...hmm
spare tire
not running the ps and a/c belts but haven't taken out the units.
yoshi234's Avatar
I shoot brides
this seems to work for several members:
warren
raging angel
TypeRmsm
yoshi - who tried this on his EF but the weight savings came a cost of horsepower
Old Dec 10, 2001 | 02:48 PM
98Psi ITR's Avatar
Default Re: Weight Loss!!! (yoshi234)
ROFL
TypeR0149's Avatar
Take out the spare tire and jack
front and rear bumper supports
ABS
AC
that will lighten you up quite a bit, while costing you no money
now lightweight rims, suspension, and brakes, can take another nice chunk out of your weight, but cost a pretty penny
[Modified by Vegeta, 6:49 PM 12/10/2001]
norice's Avatar
Rear Hatch Cover - 7lbs
Seat Bottom - 8 lbs
Rear Trim - 3 lbs
Left Trim - 7 lbs
Right Trim - 7 lbs
Seat Backs (and rear carpeting) - 14 lbs
Rear Floor Mats - 4 lbs
Rear wiper and motor ~ 3lbs
Spare Tire/Tools/Jack - 31 lbs
Stock hood is about 80 lbs. You could replace it with a carbon fibre one.
Stock exhaust and header could be replaced with a lighter aftermarket one.
If you want to go hardcore:
AC system weighs about 40 lbs.
Power steering system weighs about 20 lbs.
ABS. Lot of work to remove. Weight?
Passenger seat - 35 lbs.
Full tank of gas is ~80 lbs.
Airbags ~ 35 lbs.
Resonator - 5 lbs.
[Modified by norice, 3:55 PM 12/10/2001]
Old Dec 10, 2001 | 03:02 PM
meanteg's Avatar
New User
Default Re: Weight Loss!!! (norice)
Rear wiper and motor= 9 lbs!
WHEELS are the best place to remove weight. 1 pound removed from the outer section of a wheel= 7 or 8 pounds removed from the car.
Old Dec 10, 2001 | 03:06 PM
Cosworth's Avatar
Default Re: Weight Loss!!! (meanteg)
Actually, 1lb at the wheel = 4lbs from the car.
Old Dec 10, 2001 | 03:13 PM
norice's Avatar
Default Re: Weight Loss!!! (Cosworth)
Actually, there is no general rule for this. It depends on the diameter of the wheel, the distribution of weight on the wheel, the tyre (is weighs quite a bit too), and a bunch of other factors.
It would have to be at least four, of course, because there are four wheels on a car. A recent article on Sports Compact Car did a rough-and-ready computation and came up with a number around eight for a particular car. However, there is no general way of doing this for all cars.
[Modified by norice, 4:19 PM 12/10/2001]
Old Dec 10, 2001 | 03:45 PM
98Psi ITR's Avatar
replaced the stock hood with cf hood. I don't think the stock hood was 80lb's though or I have gotten pretty strong
I'd like to do the AC and ps assembly.
keep those tips coming
Old Dec 10, 2001 | 03:48 PM
PureTeg420's Avatar
how about buying a lightweight battery then relocating it to the trunk? You save a few pounds and get better weight distribution at the same time
Old Dec 10, 2001 | 03:50 PM
py1188's Avatar
Default Re: Weight Loss!!! (Vegeta)
ABS
AC
Couldn't getting rid of the bumper supports be pretty dangerous as far as a daily driver is concerned. AC, PS, ABS, Spare tire and jack, and interior should be more than enough weight savings, and all free of cost.
Old Dec 10, 2001 | 03:51 PM
onyx00's Avatar
Default Re: Weight Loss!!! (py1188)
Or you could just go buy a hybrid and use it as a track car. ;-)
Old Dec 10, 2001 | 04:18 PM
chad's Avatar
Moderator
me personally....gotta lose 15 pounds by the next track event
Old Dec 10, 2001 | 04:27 PM
98Psi ITR's Avatar
Default Re: Weight Loss!!! (PureTeg420)
I heard about the distribution of weight for the relocation.
Old Dec 10, 2001 | 04:30 PM
MrBite's Avatar
Where's Dave-ROR and his pics?
Monkey Fing a Coconut
May 1, 2004 01:50 AM
scorched0
Jan 8, 2004 03:48 AM
allmotorhonda
Jan 2, 2003 04:55 PM
