96 Spec Wheel Bearing - different?
Old Sep 20, 2004 | 01:26 AM
benmasters's Avatar
Default 96 Spec Wheel Bearing - different?
https://honda-tech.com/zerothread?id=994005
Hi All,
After looking at my motor this weekend I am fairly sure that my bearing is on its way out. So I will be looking at replacing shortly, and found Willards excellent bearing install thread
My question thou is the wheel bearing in a 4stud 96spec hub the same as 98 spec 5 stud.
Also I am running without brake dust shields, I wonder if that has had anything to do with the wearing of the bearing.
Old Sep 20, 2004 | 07:10 AM
Jon V's Avatar
Default Re: 96 Spec Wheel Bearing - different? (benmasters)
bump...
Old Sep 20, 2004 | 07:24 AM
Dan GSR's Avatar
not sure about the 96 jdm 4x114
but the 4x100 and 5x114 in the US use the same wheel bearing
Old Sep 20, 2004 | 07:51 AM
IN VTEC's Avatar
Pull the hub off, measure the OD of the hub, and I can give you the ID of the wheel bearing to compare.
DBada FM
Dec 8, 2009 09:44 PM
z6hatchboy
Feb 6, 2009 06:31 PM
SomeDude56
Oct 30, 2006 10:49 AM
vjace
Mar 27, 2005 10:29 PM
Jeff_B
Jul 9, 2004 11:28 AM
