ACT XACT Flywheels in stock from $197!
Old Sep 19, 2004 | 09:24 PM
prostreetonline's Avatar
Default ACT XACT Flywheels in stock from $197!
ACT offers exactly what performance enthusiasts need:
All the benefits of a lightweight flywheel, a choice of weights and affordable pricing.
Premium quality
Forged Chrome-Moly Steel
CNC Machined to exact tolerances
Precision balanced
Induction hardened integral ring gear
Stronger than cast iron, billet steel or aluminum
Durable and thick enough to be resurfaced
Certified SFI Specification 1.1 - Legal for racing
lighter than stock
Improved throttle response and acceleration
Preferred for street and drag racing
Most durable flywheel available
Better drivability than ProLite
The StreetLite is best for street and drag racing vehicles which may require more inertia.
Lightest Flywheel ACT offers
Preferred for road racing or low inertia
Quick throttle response and acceleration
Reduced drivability
The ProLite is best for road racing applications and provides quick throttle response. The ProLite is lighter than the StreetLite, and is more of a racing flywheel.
SALE! Use coupon code ACT10D for 10% off all ACT Clutches and Flywheels!
Click here to order an ACT Flywheel
Acura Integra 1990 - 2001 600105 $220.97 Trim: B series Specs: 8.8lbs - Prolite XACT Flywheel
Acura Integra 1990 - 2001 600110 $228.89 Trim: B series Specs: 12.5lbs - Streetlite XACT Flywheel
Acura RSX 2000 - 2002 600125 $236.81 Trim: Type S Specs: 9.0lbs - Prolite XACT Flywheel
Honda Civic 1990 - 2002 600130 $252.65 Trim: 224mm Specs: 8.8lbs - Prolite XACT Flywheel
Honda Civic 1990 - 2001 600115 $220.97 Trim: /CRX SOHC Specs: 8.4lbs - Prolite XACT Flywheel
Honda Civic 1990 - 2001 600120 $197.21 Trim: /CRX SOHC Specs: 11.9lbs - Streetlite XACT Flywheel
Honda Civic - 600110 $228.89 Trim: / Del Sol, Si Specs: 12.5lbs - Streetlite XACT Flywheel
Honda Civic 1999 - 2000 600105 $220.97 Trim: Si Specs: 8.8lbs - Prolite XACT Flywheel
Honda Del Sol 1994 - 1997 600105 $197.21 Specs: 8.8lbs - Prolite XACT Flywheel
Honda Prelude 1992 - 2002 600130 $252.65 Trim: 224mm Specs: 8.8lbs - Prolite XACT Flywheel
Honda Prelude 1992 - 2001 600190 $202.50 Specs: 11.9lbs - Streetlite XACT Flywheel
Mazda RX7 1986 - 1996 600140 $236.81 Trim: Turbo Specs: 9.8lbs - Prolite XACT Flywheel
Mazda RX7 1986 - 1996 600145 $236.72 Trim: Turbo Specs: 11.5lbs - Streetlite XACT Flywheel
Mitsubishi Eclipse 1989 - 1992 600150 $228.74 Trim: 6 Bolt AWD Specs: 11.6lbs - Streetlite XACT Flywheel
Mitsubishi Eclipse 1989 - 1992 600155 $228.74 Trim: 6 Bolt FWD Specs: 11.6lbs - Streetlite XACT Flywheel
Mitsubishi Eclipse 1992 - 1999 600160 $228.74 Trim: 7 Bolt AWD Specs: 11.6lbs - Streetlite XACT Flywheel
Mitsubishi Eclipse 1992 - 1999 600165 $254.15 Trim: 7 Bolt FWD Specs: 11.6lbs - Streetlite XACT Flywheel
Subaru Impreza 1996 - 1999 600180 $260.57 Trim: / Legacy Specs: 10.6lbs - Prolite XACT Flywheel
Subaru Impreza 1996 - 1999 600185 $228.89 Trim: / Legacy Specs: 13.9lbs - Streetlite XACT Flywheel
Subaru WRX 2001 - 2002 600170 $252.65 Trim: Turbo Specs: 9.6lbs - Prolite XACT Flywheel
Subaru WRX 2001 - 2002 600175 $220.97 Trim: Turbo Specs: 13.9lbs - Streetlite XACT Flywheel
To get these prices, use coupon code ACT10D for 10% off the prices on our website!
Or call us toll free: 1-888-776-7022 and mention the coupon code!
Old Sep 25, 2004 | 05:05 PM
Default Re: ACT XACT Flywheels in stock from $197! (prostreetonline)
Old Sep 28, 2004 | 04:09 PM
Bump!
allmotor1313
Nov 29, 2007 12:01 PM
prostreetonline
Nov 25, 2004 10:11 AM
prostreetonline
Oct 15, 2004 09:04 PM
tallblondkid
Jul 19, 2003 01:15 PM
BseriesHatch
May 15, 2003 06:55 PM
