Quick ECU question, please help!!!
Old Dec 10, 2001 | 01:34 PM
bigrob119's Avatar
Default Quick ECU question, please help!!!
Ok, if I am correct, the PM6 ECU is 88-91 Si/EX ECU, PG7 ECU is 86-87 Integra, and the PM7 is 88-89 Integra. OK so far? If not please correct me.
I have a 91 EX, SOHC ZC...I have the stock PM6 ECU in there right now, previously, on the D16A6 I had installed the PG7 and the engine promptly dropped 2 valve springs (and consequently, 2 rods) at high RPM. I don't think that the valve/rod problem was caused (directly) by the PG7...my lady thinks otherwise, I am not sure, so what harm, if any, can be done by using the PG7 ECU on the new engine? Please advise.
Old Dec 10, 2001 | 01:44 PM
rioninja's Avatar
Default Re: Quick ECU question, please help!!! (bigrob119)
The integ ecu has a higher rev limit than the PM6... what rpm did the motor take a ****? Also, i've heard that it runs a little lean. Were there any signs of detonation?
Old Dec 10, 2001 | 03:45 PM
bigrob119's Avatar
Default Re: Quick ECU question, please help!!! (RioNinja)
Uhhh...he he he....the morning it let go, I was racing on the fwy, held between 6800-7250 rpm in 3rd for about 5-7 seconds (racing a T-Bird SC), a few minutes after that it started knocking bad and kept getting worse and worse...I live 30 miles from work so I didn't have much choice other than to keep driving to see what was gonna happen...got to work ok...that afternoon, trying to drive home it ate 2 rods (I think, never had the block stripped down) or poked SOMETHING through the block cause about 5 minutes after I started it again (driving home at fwy speeds) it took a huge ****, one last big knock and it died...I let it coast down, stopped the car and popped the hood...oil cap was nowhere to be found(!), and behind the car, about 400-500 yards long, a trail of coolant on one side of the block (approx near the #4 cyl), and a trail of oil on the other side (near the #1 cyl)...it was some pretty crazy ****. At least I won the race.
Old Dec 12, 2001 | 08:52 PM
rioninja's Avatar
probably just a ten year old motor that finally gave out...
Andycuso
11
Apr 19, 2013 01:35 AM
zccivicex
Honda Civic (2001 - 2005)
20
Sep 29, 2009 08:14 AM
96CIVICEX
May 26, 2009 07:45 AM
itzyaboyzeem03
Aug 16, 2008 02:41 PM
ITACivic
Nov 19, 2002 04:37 PM
