4th gen, what is that sensor/solonoid on the fire wall?
Old Sep 19, 2004 | 06:46 PM
fastludeh22's Avatar
Default 4th gen, what is that sensor/solonoid on the fire wall?
it is next to the map sensor. i thought that it was part od the evap system and i just took that out.
Old Sep 20, 2004 | 09:15 PM
Qveon's Avatar
Default Re: 4th gen, what is that sensor/solonoid on the fire wall? (fastludeh22)
Evap Emissions Control Solenoid.
Old Sep 20, 2004 | 09:19 PM
Default Re: 4th gen, what is that sensor/solonoid on the fire wall? (Qveon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">IAC Bypass solenoid.</TD></TR></TABLE>
this is the one located behind the itake mainfold? with this not plugged in will it cause a 4 grand rev limit?
Old Sep 20, 2004 | 09:21 PM
Qveon's Avatar
sorry i was thinking the wrong one at first.
and yea removeing can cause irractic idle.
You need to cap off your vacumm lines.
Old Sep 20, 2004 | 09:31 PM
thats what i thought it was. i removed my whole evap system. everything is capped. i did a lot of stuff at once, including building a quick engine in 2 days...
ill fig out the problem...but if anyone knows what causes a 4k rev limit ill start there
the cel is on, but no codes show up
Old Sep 21, 2004 | 04:22 AM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">Evap Emissions Control Solenoid.</TD></TR></TABLE>
its actually the evap purge control solenoid, but same thing, if you need to know any others...here ya go
Old Sep 21, 2004 | 04:34 AM
lildrgn2.0's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought it was. i removed my whole evap system. everything is capped. i did a lot of stuff at once, including building a quick engine in 2 days...
the cel is on, but no codes show up</TD></TR></TABLE>
youve got a phantom code... Basically your ECU is wanting something to be there thats not there.. (im betting its the evap)
4 grand redlines also come from Hondata's that are messed up... also maybe an ECU.
Old Sep 21, 2004 | 07:42 AM
thehondaguru's Avatar
Default Re: 4th gen, what is that sensor/solonoid on the fire wall? (Lildrgn)
so you got the motor built???????
Old Sep 21, 2004 | 05:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn &raquo;</TD></TR><TR><TD CLASS="quote">
4 grand redlines also come from Hondata's that are messed up... also maybe an ECU.</TD></TR></TABLE>
damn i hope its not my hondata...if it is im going to freeware
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">so you got the motor built???????</TD></TR></TABLE>
nah i built a quick temp engine. h22a4 block w/my built top end. i was using it to go to nopi but it blew a hose on the way there
sageuvagony
Aug 13, 2008 10:39 AM
EFstyle
11
Jul 28, 2008 06:45 PM
b18cEK
12
Mar 29, 2006 10:18 AM
Apd3111
Jan 9, 2005 05:34 PM
