Purchased new car
Old Sep 19, 2004 | 03:33 PM
slate13530's Avatar
Default Purchased new car--We have problems now.
What's up fellas I just purchased a 91 Si w/what seems to be a ZC in it. However I'm a bit confused because the Valve cover says SOHC V-Tec and the block is stamped with just plain ZC on it. Now do I have a D16ZC or what engine code. It's too dark out for pics, but I'll try to get them up tomorrow. Oh yeah the kid who I purchased the car from informed me that the V-Tec isn't on at this moment. In any case I'll take pics of the cruddy engine bay and post up so that you guys & gals can help me decifer the engine in there.
Thanks
Modified by slate13530 at 8:58 PM 9/19/2004
Modified by slate13530 at 9:06 AM 9/23/2004
Old Sep 19, 2004 | 04:13 PM
fullblown's Avatar
Default Re: Purchased new car (slate13530)
it cant be zc if it has a sohc valve cover, u must have gotten a d16 motor
Old Sep 19, 2004 | 04:20 PM
slate13530's Avatar
Default Re: Purchased new car (fullblown)
Nah it's stamped ZC on it beleive me. I'm dazed & confused about it. It's not stamped D16 it's just plain ZC on it.
Old Sep 19, 2004 | 04:26 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullblown &raquo;</TD></TR><TR><TD CLASS="quote">it cant be zc if it has a sohc valve cover, u must have gotten a d16 motor</TD></TR></TABLE>
wrong...
you have a ZC, its just an obd1 sohc vtec...
Old Sep 19, 2004 | 04:36 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: Purchased new car (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
wrong...
you have a ZC, its just an obd1 sohc vtec...</TD></TR></TABLE>
yep, if I remember correctly there are three different ZC's.
GoFastMotorSports's Avatar
wrong...
Exactly. Is it similar to the d15b? I know the d15 is 1.5L, I was just wondering
Old Sep 19, 2004 | 04:45 PM
slate13530's Avatar
Default Re: Purchased new car (GRCCRX911)
Pics will be up shortly. I remember reading that there's three different types of ZC engines that were made, but I would like to know which one I have.
Old Sep 19, 2004 | 04:46 PM
crxdx89's Avatar
lol, this is great.....
its most likely a SOHC ZC block, with a SOHC VTEC head (d16z6)
does the head have the vtec solenoid?
Old Sep 19, 2004 | 04:48 PM
Crakadic's Avatar
Or it just has the Vtec Valve cover......
Old Sep 19, 2004 | 04:56 PM
slate13530's Avatar
Default Re: (Crakadic)
These are the pics I just took. Tomorrow I'll take some day light pics.
Old Sep 19, 2004 | 05:01 PM
crxgator's Avatar
Default Re: (slate13530)
yup, sohc vtec zc, similar to the USDM D16Z6...
Old Sep 19, 2004 | 05:04 PM
-16V-'s Avatar
Default Re: (crxgator)
Mini-Me...
Old Sep 19, 2004 | 05:05 PM
slate13530's Avatar
Thanks gator that's what i figured.hopefully i'll have this car ready by the spring.
Old Sep 19, 2004 | 05:06 PM
Crakadic's Avatar
Thats a good start for a engine especially if you didnt build it. Get a few add on's and you should hit 15's
Old Sep 19, 2004 | 05:22 PM
crxdx89's Avatar
Default Re: Purchased new car (crxdx89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdx89 &raquo;</TD></TR><TR><TD CLASS="quote">lol, this is great.....
Old Sep 19, 2004 | 05:23 PM
slate13530's Avatar
Yeah I didn't build it, but soon I will. It has a CAI that I took off and put in my current car because this one won't be running for a while.
Old Sep 21, 2004 | 03:30 PM
slate13530's Avatar
Maybe some of you could help me out here. Got the car started, but the CEL is on and the LED on the computer is just straight blinking. Is there anything I should look for that isn't wired up other than the V-Tec. LMK please
Thanks in advance
Old Sep 21, 2004 | 06:38 PM
Bserieskllr's Avatar
yea im gonaa have to say obd1 zc vtec...i know some1 else that has a turbo one runs strong...good luck with the new car.
Old Sep 22, 2004 | 03:40 AM
slate13530's Avatar
Default Re: (Bserieskllr)
Thanks
Old Sep 23, 2004 | 05:08 AM
slate13530's Avatar
The car starts when comepletely cold, but once it warms up its bogs and shuts off and won't start back up. CEL came on. The codes I got off the ECU Led are as follow:
3 flashes Pause
13 flashes Pause
14 flashes and then it goes back to code three.
Should I bother to test these trouble units or should I just replace them? If I replace them what engine or model & year car should I get them from since it's a SOHC ZC. Any input would be greatly appreciated.
Thanks
Old Sep 23, 2004 | 05:31 AM
tylercrx's Avatar
you got the codes, now do you know what they mean? whether you should replace your motor depends on your budget, and seeing that you bought this car as it is, you should troubleshoot each of the problems. plus its fun and gives you some quality time with your "new" car.
check out http://www.pgmfi.org or use the SEARCH button to find out what the codes mean. Search on Honda-Tech will be your best friend. Good luck.
Old Sep 23, 2004 | 06:55 AM
slate13530's Avatar
Default Re: (tylercrx)
No, I know what the codes mean. MAP sensor and EACV, but I'm just confused about what make & model the parts should be purchased for....that's my real question. I'm going to test these parts when I get home. I figure I'll just take them off my current running car and see what happens.
Old Sep 23, 2004 | 03:28 PM
slate13530's Avatar
Okay anyone that can help me out or give me suggestions I will gladly apprecaite it.
When I got home this afternoon I noticed something above the stock MAP sensor being unplugged. Plugged it back it and tried starting the car. It started up and the only code I was gettign is #3.
Let the car warm up, but I had to help it out a little bit once at full temp it just shut right off. It'll crank and crank, but not fire up. Anyone know if the MAP will cause this to happen?
Anyone with suggestions or tips ?
Thanks
Old Sep 24, 2004 | 05:18 AM
slate13530's Avatar
Bump to the top
Update up above.
Car starts up and warms up, but then it shuts off once it's at full temp and won't start back up until it's completely cold.
Old Sep 24, 2004 | 05:34 AM
GreenMachineRex's Avatar
sohc zc. NOT mini me. you cannot purchase the old stock si d16 motor anymore. if you 'buy' one online u will get the sohc zc. its only got a coulpe more horses if im right. 118hp i think.
as for the warmin thing. never ever ever heard of crazy **** like that. replace ur thermo or some ****.
