h23 with h22 pistons and head
Old Sep 19, 2004 | 12:40 PM
hOndafienD 04's Avatar
Default h23 with h22 pistons and head
would i have any piston to valve clearnace with stock cams?
Old Sep 19, 2004 | 04:54 PM
H23vtecEG's Avatar
Default Re: h23 with h22 pistons and head (hOndafienD 04)
no problem whats so ever
Old Sep 20, 2004 | 04:29 PM
h22 pistons go right on the h23 rods? or must i use h22 rods?
Old Sep 20, 2004 | 11:27 PM
red92si's Avatar
You have to have the H23 rods rebushed to accept the floating wristpin used on the H22 pistons.
Old Sep 20, 2004 | 11:40 PM
SKDRCR's Avatar
Default Re: (red92si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92si &raquo;</TD></TR><TR><TD CLASS="quote">You have to have the H23 rods rebushed to accept the floating wristpin used on the H22 pistons. </TD></TR></TABLE>
Actually, I believe that it's the type-s pistons that are floating
wrist-pin design.
I don't think you have to rebush them with regular h22a1 pistons.
Old Sep 20, 2004 | 11:47 PM
red92si's Avatar
Regular H22 pistons all use floating wrist pins. Joel (Satan) will back me up on this.
Old Sep 21, 2004 | 09:22 AM
so best thing to do is get a 2nd pair of h23 rods and rebrush them??? can you inform me on this process....or should i just take them to the machine shop and ask to place the h22 pistons on the h23 rods?
Old Sep 21, 2004 | 10:15 AM
red92si's Avatar
If you already have an H23, then you can take the rods you have now and ask a compitent machine shop to rebush them to accept a piston with a floating wrist pin.
Or you can do this to a second set of H23 rods... either way, any compitent machine shop should be able to rebush them.
Old Sep 21, 2004 | 03:46 PM
aiight thanx...yeh i will buy a 2nd pair cuz i wanna do this conversion in a 1 day time period...should i go usdm h22, jdm h22, or type s pistons? this is for street application...i need it to run on pump gas
Old Sep 21, 2004 | 05:21 PM
also is there a certain year i should be looking for? this guycan get me usdm h22 pistons with rods which i dont need for 99 bucks. they are from a 93, he says non floating...so im guessing these wont work..correct?
Old Sep 21, 2004 | 06:01 PM
PirateMcFred's Avatar
Default Re: (hOndafienD 04)
check PM
Old Sep 22, 2004 | 09:31 AM
yohan's Avatar
Are there any other engines that will support this ??? H blocks are $$ compared to F ..
Whats the cheapest way to do this buying used parts ?
Anything F series work ? ...
I am thinking about giving more stroke my H22
Old Sep 22, 2004 | 11:17 AM
Eddiebx's Avatar
only the 97+ use floating wrist pins, the h22a1 and jdm h22a, have pressed pins
krayzieboi213
Jul 7, 2008 07:35 PM
flip1199
Oct 24, 2003 03:57 PM
user 9782082308
Sep 7, 2003 09:40 AM
H23A1LUDE
Mar 3, 2003 07:38 AM
H22Prelude
Nov 17, 2002 08:55 PM
