Which ACT clutch would be best for my setup??
Old Sep 19, 2004 | 09:38 AM
Lifter2012's Avatar
Default Which ACT clutch would be best for my setup??
Hey guys, well at 52xxx miles the stock clutch has given up all hope i had in it so it's time for a new setup. I am looking at either a stock Type R clutch and a lightened flywheel, or an ACT HDSS or XTSS clutch. My mods are currently just an AEM Cold Air but in a week my SMSP header and exhaust will come. I use the car for daily driving and mostly A LOT of highway driving. This s what I have heard, the pedal pressure of the HDSS is actually slightly heavier than stock. Perfect for daily use. While it might feel like stock, it is slightly stiffer and engages a bit lower. Would there be any advantages to going to the XTSS over the HTSS with my setup?? I've researched but I would just like some more input on the XTSS clutch, thanks fellaz
Old Sep 19, 2004 | 11:19 AM
Rory Breaker's Avatar
Default Re: Which ACT clutch would be best for my setup?? (Lifter2012)
For your setup? Nope, no advantage except a bigger calf muscle.
Id stick with the HDSS unless you plan on getting real serious with the car.
Old Sep 19, 2004 | 11:30 AM
SoCal ITR's Avatar
Default Re: Which ACT clutch would be best for my setup?? (newgsrdriver)
I have the HDSS/8.8 setup and if I had to do it again, I'd go with the XTSS setup and the lightest flywheel I could find.
Old Sep 19, 2004 | 11:34 AM
Lifter2012's Avatar
Default Re: Which ACT clutch would be best for my setup?? (SoCal ITR)
What are your reasons please if you dont mind me asking
Old Sep 19, 2004 | 11:47 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lifter2012 &raquo;</TD></TR><TR><TD CLASS="quote">What are your reasons please if you dont mind me asking </TD></TR></TABLE>
I decided that even after the lighter flywheel, I could still go lighter... and as for the HD vs XT... if you do some searching there's an odd noise that appears to be a result of the HD in the HDSS setup. I don't think it affects anything, but it gets annoying sometimes. Not everyone experiences it though...
Old Sep 20, 2004 | 11:06 AM
slammedCL's Avatar
Id personally go with the XTSS/8.8 setup from experience with my old gsr. It didn't feel that heavy and shifted much smoother throughout the gears just my 2 cents.
Old Sep 20, 2004 | 11:14 AM
Bbasso's Avatar
I have the XTSS and the Comptech Al FW for over a year, If I were to do it again I would get the HDSS- reason I don't have the modulation I would like to have in the XTSS for the track and the street. Basically I want a softer pedal with the grab of the XTSS.
Get the lightest FW you can afford. There is nothing negative about it.
Get a decent clutch but going all the way is not needed in a sub 200whp R.
Old Sep 20, 2004 | 12:06 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">
I decided that even after the lighter flywheel, I could still go lighter... and as for the HD vs XT... if you do some searching there's an odd noise that appears to be a result of the HD in the HDSS setup. I don't think it affects anything, but it gets annoying sometimes. Not everyone experiences it though...</TD></TR></TABLE>
Yeah the noise is kind of weird, it only happens when letting off the clutch and giving it too much throttle, its kind of like a howling sound. I had that setup on my stock B16 when I had my hatch and a friend with the same setup on a cable trans CRX experienced a similar sound. Never had any problems though.
Kicker773's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">For your setup? Nope, no advantage except a bigger calf muscle.
Id stick with the HDSS unless you plan on getting real serious with the car.</TD></TR></TABLE>
stick with that setup hdss..
Old Sep 20, 2004 | 12:28 PM
slammedCL's Avatar
Default Re: Which ACT clutch would be best for my setup?? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">I have the XTSS and the Comptech Al FW for over a year, If I were to do it again I would get the HDSS- reason I don't have the modulation I would like to have in the XTSS for the track and the street. Basically I want a softer pedal with the grab of the XTSS.
Get a decent clutch but going all the way is not needed in a sub 200whp R.</TD></TR></TABLE>
Exactly what he said...Get the lightest FW you can afford. It's worth it in the long run bro.
Jdm_driver4
Transmission & Drivetrain
Mar 6, 2012 07:09 AM
JDMFreak_DC2
Aug 6, 2009 04:18 AM
F20Cdriver
Honda S2000
Oct 8, 2007 03:35 PM
GSRrR
Apr 29, 2004 02:27 PM
P1mpSlap
Apr 20, 2003 10:26 PM
