HELP with my tranny please!!!!
Old Sep 19, 2004 | 07:40 AM
illestrolla247's Avatar
Default HELP with my tranny please!!!!
my tranny is impossible to shift when driving
sometimes i have to stop and shut the car off to get it in gear
it just doesnt want to go in
once in gear it stays in but somtimes i cant even get it in the gear
when the car is off it shifts fine
anyone have any ideas or suggestions
Old Sep 19, 2004 | 08:49 AM
blah13's Avatar
Default Re: HELP with my tranny please!!!! (illestrolla247)
Clutch cable is too loose, your clutch is always engaged thus not letting you shift. Try tightening your cable, otherwise you've got internal problems, throw-out bearing, pressure plate etc.
Old Sep 19, 2004 | 10:17 AM
Default Re: HELP with my tranny please!!!! (blah13)
clutch works fine
when i can get it into gear and i clutch it operates fine its just the actual moving from gear to gear that is REALLY tough
i have to use 2 hands somtimes
Old Sep 19, 2004 | 10:38 AM
ServiceAdvisor's Avatar
Those were symptons I had when my differential cracked and bit into the axel ring clip. My tranny ended up taking a dump on me at 50 mph. Does your shifter ever start to knock like it someone is hitting it with a hammer, that was my second symptom before it blew apart. I would try first checking to make sure your tranny fluid level is good or maybe replace it with some Honda MTF you can get from any Honda/Acura Dealer. Could be simple, could be major, be careful when trying to jam it into gear cause it might lock up on you without warning. - Darrell
Old Sep 19, 2004 | 11:25 AM
Default Re: (DOHCZCCRXSi)
how about a bent or broke shift fork
will that cause these symptoms
Old Sep 19, 2004 | 12:45 PM
Default Re: (illestrolla247)
bump
Old Sep 19, 2004 | 06:11 PM
exactly what you said clutch cable was loose
Old Sep 19, 2004 | 08:24 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illestrolla247 &raquo;</TD></TR><TR><TD CLASS="quote">exactly what you said clutch cable was loose</TD></TR></TABLE>
Good to hear.
Old Sep 19, 2004 | 08:27 PM
Loaded Butane's Avatar
Glad it was something simple. When I had that problem it ended up being the PP.
01_em2
Transmission & Drivetrain
Sep 30, 2010 02:37 PM
blueintegra90
Feb 10, 2004 06:37 PM
XES
Jul 18, 2003 09:22 AM
tilt
Oct 7, 2002 01:22 PM
2latev8
Dec 19, 2001 06:57 AM
