Blowing fuses!!!!!!!
I have had this problem for awhile and need to get it fixed. I am currently blowing my turn signal fuse as soon as I use my turn signal. Also blowing are my cluster fuse and climate control/ fan unit fuse every so often. I went from tan interior to black and back to tan awhile ago and am still dealing with this problem. I am assuming the wires are touching metal somewhere which inturn is causing the short, but before I take apart my dash again and run the wires AGAIN I would like to know if anyone else has ran into this problem also. If so how did you correct it. Thanks in advance.
youre electical system is shorting out somewhere. only main way to fix it is to find the short. use a meter or just start from scratch to figure out where it might be. you can use a helms to figure out what harnesses are central to the turn signal fuse.
ProjectDarkBlack
Jun 10, 2007 07:56 PM
