apc short shifter
i installed an apc SS when did my b16 swap. i notice that when you shift from any gear to any rear it doesn't shift smoothly. i don't gring or anything, i guess the best way describe it is like if your car was stopped and you try to put it in reverse and it won't slide in, you almost have to give it a little extra mucsle and then it goes into gear. it kinda feels like its just not alinging correct. hope that make sence. anyhow is that normal on these trannies or is the apc thing not lineing the syncros up right?
i have a skunk2 shifter so it could be similar. you may need to loosen that long bolt w/nut that slides through the shift linkage and short shifter. mine was being stubborn until i adjusted it. haven't had a problem since.
88EFhatch
14
Jun 8, 2005 06:11 PM
crxzcracer
10
Jun 20, 2004 09:54 PM
STHPERFORMANCE
Dec 18, 2003 11:37 AM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
