turbo a6..anyone got a set-up
wsup, right now im in the phase of swap or turbo..i just want my car in the 13's daily driven for now.. soo far i have a a6,55 shot of zex wet kit, h/i/e ,msd upgrade 2" piping stage 2 clutch...im running somewhere in the 14mids and want to know what i have to do internally to be able to boost 7psi with the above set-up without kaablooom on my motor...also would that get in somewhere in the mid 13s?? thank you...i would also appreciate those who like to share their set-up on there car
Internals are fine up to 12 psi as long as you tune away from Detonation and overheating.
Proly even more with a more sophisticated Fuel Management system.
since you have a d16a6 you can use turboedit, rom editor, assuming you're still obd0. With bigger injectors you can dyno tune it or get a wideband a/f gauge and egt to street tune safely. A lot of guys here have the latter, I can't afford it yet.
Talk to xenocron or turboef9, they're the guys pushing turboedit and street tuning
to tune away from detonation, you could use a thicker head gasket, thats probably the cheapest way, you could use a y8 gasket i think or just get a thick copper one, those are nice but expensive i hear. if you have money go with low compression pistons. on a stock internal d-series its very safe to run 8-10 lbs of boost since they are one of the most reliable honda engines. could be wrong about the y8 though, look into it more.
http://www.turbod16.com
these guys know thier sh*t
