Endless searching has led me here! d16z6 questions
Old Sep 18, 2004 | 04:49 PM
LS_crxjhm's Avatar
Default Endless searching has led me here! d16z6 questions
My question is about the Non OBD-OBD1 conversion harness, a friend has a DX hatch that we are about to drop a 95 d16z6 into. He wants to use the 95 ecu. My question is if i to the DPFI-toMPFI swap, and use one of the Conversion harnesses, Where will the wires for the grounds on the injectors run to? Do we need to go to the junk yard and get that little plug that the 92-95s use or use the resistor box from a MPFI car? He wants to use the obd-1 injectors, dizzy, and ecu.
Old Sep 18, 2004 | 06:42 PM
Gant's Avatar
Default Re: Endless searching has led me here! d16z6 questions (LS_crxjhm)
wire it up 92-95 civic style all the wires for the injectors get soldered together
Old Sep 18, 2004 | 09:41 PM
thumbtack's Avatar
Default Re: Endless searching has led me here! d16z6 questions (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">wire it up 92-95 civic style all the wires for the injectors get soldered together</TD></TR></TABLE>
All the power wires get soldered up together. Then you run the two extra injector pulse wires from the existing dash harness. Basically you remove the dx ecu then you add the wires now making your dash harness look like a Si model's harness. Put the conversion harness in and connect the p28 ecu. done.
check out http://fourthgenhatch.com Look under the how-to's page for the mpfi swap... It's what I used to figure out the mpfi swap and obd1 conversion.
Old Sep 19, 2004 | 02:30 AM
StorminMatt's Avatar
You need tio add wires (with pins) to proper positions of the A plug on the CRX dash harness for the two additional injectors. Keep in mind that although there are four injector wires connected to the A plug on a DX, two are duplicates. Also keep in mind that you will probably have to move and add distributer wires among the B and C plugs. Unfortunately, it seems like all the available ECU adaptors are made for MPFI models. So you will have to wire up the plugs like a MPFI car.
89ED
Jan 20, 2017 05:37 PM
JRZ88DX
24
Apr 11, 2010 07:16 PM
project91crxsi
Aug 23, 2009 09:11 AM
DSRxSALSA
Oct 22, 2005 01:19 PM
thumbtack
Jul 8, 2004 05:24 AM
