Jdm 1 pieces for 91 teg
Old Sep 18, 2004 | 04:08 PM
slammedtegls's Avatar
Default Jdm 1 pieces for 91 teg
I recently bought the 1 piece headlights and am having trouble getting the bumper screws out and secondly I have no idea on how to wire it? i realized that the corners of the jdm one has one blub but the usdm has 2 whats the deal?
Old Sep 18, 2004 | 06:02 PM
Xsi's Avatar
Xsi
Which screws are you having trouble with? You don't need to take them all out http://www.integra.orcon.net.nz/resonator
Old Sep 18, 2004 | 06:47 PM
DA9RsIntegra's Avatar
Default Re: (Xsi)
With the corner-light, just figure out which one blinks with the blinker, and use that one.. With the wiring, its very straight forward, just match the wires on the harness, i.e. the two on top and one on side.. I think, or was it one on top, and two on side. And which bumper screws are you having trouble with.. ??
Old Sep 18, 2004 | 06:50 PM
oldDude's Avatar
Default Re: Jdm 1 pieces for 91 teg (slammedtegls)
Yes, please be a bit more specific about your problem getting the bumper off. As for the corners, take your pick. Just tuck the other bulb/plug away somewhere safe.
Old Sep 18, 2004 | 07:34 PM
Endless STi's Avatar
Default Re: Jdm 1 pieces for 91 teg (oldDude)
r u talking about the 2 screws that r under the headlights on each side? well if u r i tried taking out my bumper wen installing my cai and it was a bitch. so i decided to yank that ****** out. u dont need those 2 screws neways.
Old Sep 18, 2004 | 08:15 PM
Default Re: Jdm 1 pieces for 91 teg (Bootleg R)
when you pop the hood and inbetween the headlights are the 4 metal screws. Is it safe to just tuck the bulb in there?
Old Sep 19, 2004 | 05:08 PM
Chris_Bye's Avatar
http://www.g2ic.com ...teg tips has the whole install.
Old Sep 20, 2004 | 03:20 AM
Sleepr56's Avatar
Default Re: Jdm 1 pieces for 91 teg (91ntegra)
1 Pieces are a busy work install. All your work will be in wiring. The bumper comes off with the two bolts behind each bumper lense, and you need to remove the 2 screws on each inner fender lining holding tight to the bumper. Then you and a buddy wiggle and bumper and it pops right off. The light has two mounting brackets under each headlight that you will most likely need to transfer over to the new headlights, and then 3 bolts in the engine bay hold the rest of the light in place. As for the corner lights you have a choice to leave it a constant, or a constant with flashers. I left mine constant, b/c i have plans for sidemarkers.
PowerLeg
Apr 28, 2009 11:59 AM
B-B-K
Mar 17, 2006 10:48 AM
rcktmn411
Oct 9, 2004 03:40 PM
es_squared
Feb 10, 2004 03:21 AM
Luder85
Aug 24, 2003 10:19 AM
