installed head w/o dowel pins (woops)
Old Sep 18, 2004 | 04:05 PM
tuan...'s Avatar
Default installed head w/o dowel pins (woops)
After having an oil leak at the headgasket for so long, I decided to finally take a day off and take off my head. When i took it off, my friend was like "uhh.. how come ur head slides?, do u not have dowel pins?" and im like, uhh i dont remmeber any dowels pins being put in"
long story short, i realize i threw away the dowel pins the last time I had my head off, becuase the didnt look like anything important. (the machine shop took out the dowel pins, and put them into a little baggie w/ a bunch of other stuff from the head) so i though o maybe its jus junk and i threw it away.
so yea, anyways, i put my head back together w/o dowel pins, jus the head bolts lining everything up. needless to say, i fukked up. the head gasket was like 2-3mm out of alignment and it left those nice rings seeen in the pics below. Im thinkin that is also the cause of my head gasket leak.
When i did my compression test with the head gakset like that, i had about 170-180 on the cylinders. i assumed my motor was really weak, and old. would it make sense for the compression numbers to be low due to the head gasket like this?
Old Sep 18, 2004 | 04:55 PM
LudeyKrus's Avatar
Yes, it's probably because of the headgasket sliding around.
Get those dowel pins back in bish!
Old Sep 18, 2004 | 05:00 PM
tuan...'s Avatar
done did, got them off of a b18, i think they're the same size. o btw, off subject here but, if theres a bunch of intake manifold gasket material in the intake ports, is that bad? i just finished scrapping all that **** off and now im stuck with a bunch of it in my ports..
Old Sep 19, 2004 | 10:28 AM
LudeyKrus's Avatar
Default Re: (v0gueSilver_Dc2)
YES!
Get some compressed air or something and blow it out, or if you have the head out you can use a something else to scrape it all out. You don't want that junk falling into your combustion chamber!
InvaderTrax
Nov 21, 2008 08:06 PM
SlowPokeEg
Mar 22, 2008 09:10 PM
Tigfab
Jun 3, 2007 03:04 PM
tuan...
Sep 18, 2004 09:50 PM
blwnb16a
Dec 18, 2003 02:59 PM
