took my head off (would this be the cause of low compression?)
Old Sep 18, 2004 | 04:03 PM
tuan...'s Avatar
Default took my head off (would this be the cause of low compression?)
After having an oil leak at the headgasket for so long, I decided to finally take a day off and take off my head. When i took it off, my friend was like "uhh.. how come ur head slides?, do u not have dowel pins?" and im like, uhh i dont remmeber any dowels pins being put in"
long story short, i realize i threw away the dowel pins the last time I had my head off, becuase the didnt look like anything important. (the machine shop took out the dowel pins, and put them into a little baggie w/ a bunch of other stuff from the head) so i though o maybe its jus junk and i threw it away.
so yea, anyways, i put my head back together w/o dowel pins, jus the head bolts lining everything up. needless to say, i fukked up. the head gasket was like 2-3mm out of alignment and it left those nice rings seeen in the pics below. Im thinkin that is also the cause of my head gasket leak.
When i did my compression test with the head gakset like that, i had about 170-180 on the cylinders. i assumed my motor was really weak, and old. would it make sense for the compression numbers to be low due to the head gasket like this?
Old Sep 18, 2004 | 09:50 PM
BlueIntegraBoy's Avatar
Default Re: took my head off (v0gueSilver_Dc2)
Yes, the headgasket was your cause for lower compression. Especially if it's misaligned and leaking oil.
SlowPokeEg
Mar 22, 2008 09:10 PM
Tigfab
Jun 3, 2007 03:04 PM
DC2SIR-G
Oct 17, 2005 01:54 PM
tuan...
Sep 19, 2004 10:28 AM
blwnb16a
Dec 18, 2003 02:59 PM
