Oil pan similarities
Old Sep 18, 2004 | 11:04 AM
Shakes's Avatar
space cadet
Default Oil pan similarities
i know that one of the oil pans is steel and one is aluminum. just cant remember which one. is it the 4th or 5th gen that is steel?
and will that bolt to an H22a4?
on my drive to nopi last night i think i cracked mine cause i covered the road in oil.
Old Sep 18, 2004 | 11:41 AM
2lude4u's Avatar
Default Re: Oil pan similarities (Shakes)
4th gens are steel as well as some 5th gens. I believe it was in 2000 that 5th gens started getting aluminum oil pans. The two pans should be interchangeable, the manner in which they bolt up to your tranny for additional regidity is different though. The steel pans use a simple two bolt bracket, while the aluminum pans utilize a larger bracket the provides better rigidity. So make sure you pick up one of those bracket when you get a steel pan.
equinox
Jul 7, 2006 12:55 PM
preludeshdriver
Aug 24, 2005 08:08 PM
Prez808
Jun 4, 2003 09:30 AM
G3gsr
Jan 13, 2003 04:40 PM
BlueShadow
Dec 27, 2002 02:28 AM
