motor mount question
From: Seattle/Ligonier, WA/PA, United States of Honda
the mount that is directly connected to the block on the drivers side, can the studs that you screw the nuts on to be replaced with the shorther ones off my d series eninge, if so how?
im pretty sure you can but why? any way you put two 14 (or 17mm) nuts on the stud flush up to each other then with them tight just unscrewe the stud out of mount.
