Gsr pistons in an LS?
Old Dec 10, 2001 | 06:24 AM
TurBoTeG's Avatar
Default Gsr pistons in an LS?
anyone know approx how much hp you will get at the wheels from doing this? Im thinking about maybe 10 or so (NA) ...anyone here done this?
Old Dec 10, 2001 | 06:37 AM
pregunta's Avatar
Default Re: Gsr pistons in an LS? (TurBoTeG)
I put gsr pistons in a ls\vtec. Yes you will notice a difference. Don't know exactly how much horse but enough. Will have to get the pistons or rods modified to put them in though. either 1. The rod heads have to be ground down so they will fit into the piston or 2. A small bit has to be taken out of the pistons on each side so the rods will fit. I did 2. You might want to check out piston valve clearance and also CR for your application though.
Old Dec 10, 2001 | 07:18 AM
OneThirtyEight's Avatar
Default Re: Gsr pistons in an LS? (pregunta)
I have ITR pistons in my LS. I like it.
Old Dec 10, 2001 | 08:54 AM
MRXMUFFIN's Avatar
Default Re: Gsr pistons in an LS? (97blackteg)
97blackteg, did you have to modify anything else to fit the ITR pistons in?
young geezer
Oct 15, 2010 05:13 PM
sleepencivic
May 13, 2010 08:50 AM
danthemang3
Jun 3, 2005 05:57 PM
B2FiNiTY
Aug 27, 2003 09:48 AM
velocitysir
Jun 9, 2002 07:05 PM
