Car dies after I press the clutch in, NEED HELP!!!
Old Sep 18, 2004 | 08:12 AM
sway892's Avatar
Default Car dies after I press the clutch in, NEED HELP!!!
I have GSR turbo set-up , just put the clutch in about 3 or 4 months ago.
The car has been making noise every time I press the clutch in, I could
hear the release bearing making it. Now I asked my stepdad to look at the
car and he said the bearing is seized, he says that the reason for the car
wanting to die after I press the clutch in. Has Anybody had this problem? if
so can you please tell me what the problem was.
Old Sep 18, 2004 | 08:34 AM
earl's Avatar
Default Re: Car dies after I press the clutch in, NEED HELP!!! (sway892)
If you drove with your foot resting on the clutch or did not have the clutch adjusted properly, that can wreck the TO bearing.
If the TO bearing is ok, you could be wiping out the rear thrust washer inside your engine. That will also cause the engine to freeze when you push in the clutch. Lets hope it is the clutch and not internal.
Old Sep 18, 2004 | 11:41 PM
sway892's Avatar
Default Re: Car dies after I press the clutch in, NEED HELP!!! (earl)
Yo thanks for replying, THis is what I did. I took the transmission out and
replaced the TO bearing. The problem was still going on, so my stepdad
took a closer look and it's the crankshaft bearing.
The problem with the car is that when I press the clutch, the entire
crankshaft assembly shifts over towards the pulley. Thats probably the
reason why I snapped two alternator belt in two weeks. Since the
crankshaft shifts over so do the connecting rod, pulley and belts .
He said that the crankshaft bearing need to be replaced as soon as
possible. As I was driving home today the noise was getting louder,
sounds like a piston is hitting a valve or piston slap. I hope that its just the
main bearings and nothing else, Thanx for replying.
Where's the rear thrust washer? engine or block? whats the exact location?
Old Sep 18, 2004 | 11:51 PM
b18cx's Avatar
you know you have crank walk and your still driving it? Hope its beacuse your almost done building the other motor your going to put in there.
Old Sep 18, 2004 | 11:52 PM
sway892's Avatar
Default Re: Car dies after I press the clutch in, NEED HELP!!! (b18cx)
is it really that bad?
Old Sep 21, 2004 | 08:03 PM
cinq's Avatar
bad bad...really really bad....i guess i won't see you at the street races? safer for u to stay home and watch the eagles...or whatever you like to watch...cartoon network..etc
Old Sep 22, 2004 | 06:31 PM
sway892's Avatar
Default Re: Car dies after I press the clutch in, NEED HELP!!! (cinq)
cartoon network.............who told you? My luck one of my friends had a
block laying around and he gave it to me. I Took the bottom of the block
out and it's not looking good for my old crankshaft. The spare block I have
has all the same components and they are in great shape. I'll swap all that
stuff out this weekend, I'm debating on wether or not to sell the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq &raquo;</TD></TR><TR><TD CLASS="quote">i guess i won't see you at the street races? </TD></TR></TABLE>
When are you going to make an appearance at the races?
Zteve
Nov 18, 2009 08:46 AM
IneedBoostInTheCoupe
Nov 13, 2006 03:22 PM
petty$rep
Oct 31, 2006 08:45 PM
JdmFront619
Oct 28, 2003 12:25 PM
rockwilda
Jun 19, 2002 03:57 PM
