stage 2 cams for 95 civic?
best thing to do is figure out who's "stage 2" cams you're looking at buying and then have a look at their website and they'll tell you what kind of power output you'll get on your particular application.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robtec »</TD></TR><TR><TD CLASS="quote">crower stage 2 cam
i made 154whp@7750rpm with it
were you running crower valve train as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1civic95 »</TD></TR><TR><TD CLASS="quote">damn thats nice. yeah what else you doing to the car ? VAFC or anything to tune with ?? ADj cam gear??</TD></TR></TABLE>
adj cam gear @-2*
xs chip
no tunning
i'm not running the crower valvetrain,stock z6 springs and retainers
it made 154whp on a mustang dyno..but i test it before the skunk 2 im. and exhasut and it made 138whp on dynojet,so i'm guessing it may put mid 140s now on a dynojet(same one)
i don't have the print out of the the dynojet run,this one is from the mustang dyno
adj cam gear @-2*
xs chip
no tunning
adj cam gear @-2*
xs chip
no tunning
wtf mods list??? thats more than a modded b16....
adj cam gear @-2*
xs chip
no tunning
</TD></TR></TABLE>wtf mods list??? thats more than a modded b16....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 »</TD></TR><TR><TD CLASS="quote">first of all its "cam" you only have one. thus its not "cams" unless you have one or more.
crower=junk, they use weak cores and will break over time. get a Zex or something similar</TD></TR></TABLE>
who gives a **** those are some nice numbers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memic »</TD></TR><TR><TD CLASS="quote">How much HP will stage 2 cams give my 95 civic ex d16z6? Thanks for any help.</TD></TR></TABLE>
i hate these stupid bullshit terms companies use. "stage 2 clutch, stage 2 cams" such crap, that doesnt MEAN ANYTHING. get the REAL information about the cam, lift, duration, overlap etc.
from d-series.org
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsgtrip »</TD></TR><TR><TD CLASS="quote">I recently switched from a Zex 2 cam to a Crower 2 cam. I definitely like the Crower 2 much better. Zex cam had pretty midrange, but lacked high rpm power. The Crower makes lots of power in Vtec, especially after 6500 rpms. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">i hate these stupid bullshit terms companies use. "stage 2 clutch, stage 2 cams" such crap, that doesnt MEAN ANYTHING. get the REAL information about the cam, lift, duration, overlap etc. </TD></TR></TABLE>
crower stage 2 cam
Advertised Duration - Duration @ .050" - Gross Lift w/ 1.6 int / 1.8 exh
276 / 255 - 230 / 204 - 427 / 432
intake opens 8.5 btdc
closes 46.5 abdc
exhaust opens 40.5 bbdc
closes 2.5 atdc
lope separation 109*
i shift at 8400 rpm,with oem springs and retainers for about a year now with no problems and the cam do not show any sign of wear yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">wtf mods list??? thats more than a modded b16....</TD></TR></TABLE>
y8 bolck-stock z6 head
pg6b pistons-pm7 rods
crower stage 2 cam
skunk 2 im. and and adjustable cam gear
afpr (55 psi)
custom intake
ractive 4-2 header
no cat
2.25-2.5 custom exhaust
xs ebay chip
act clutch
no a/c & p/s
Modified by robtec at 11:02 PM 9/19/2004
crower stage 2 cam
closes 46.5 abdc
closes 2.5 atdc
crower stage 2 cam
afpr (55 psi)
custom intake
ractive 4-2 header
no cat
xs ebay chip
act clutch
no a/c & p/s
i love crower, i wont go with anything else but crower...you dont need an adjustable cam gear for the crower stage 2 cam because there ground is already set to "0"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">zex doesn't have **** on crower, go crower if you are gonna turbo most definitely. i have heard bad things about zex</TD></TR></TABLE>
obviously you don't know **** about the zex cam. People have seen over 20whp on turbo setups with their stage 2 cam. I even have it in my setup and it pulls super strong.
I have never heard of anyone having problems with the sohc crower cams. I've only heard good things. DOHC on the other hand is a different story. I've heard of plenty of those breaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclpze97 »</TD></TR><TR><TD CLASS="quote">i love crower, i wont go with anything else but crower...you dont need an adjustable cam gear for the crower stage 2 cam because there ground is already set to "0"</TD></TR></TABLE>
that doesn't mean you still won't make more power by retarding it a couple of degrees or something. An adjustable cam gear is always a good idea if you want to get the maximum amount of power out of your cam.
The companies do that so you can tell a differance between cams when speakin about them... instead of saying oh i have the blah blah lift, with the blah blah blah duration, at the blah blah blah you can say, I have the skunk2 stage 2. then you can go and look up what the specs are on the cam.
good idea, no?
good idea, no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene »</TD></TR><TR><TD CLASS="quote">
good idea, no?</TD></TR></TABLE>
no its a stupid idea
good idea, no?</TD></TR></TABLE>no its a stupid idea
so he has "cams".... right???
