Will SSR Type C 4x100 15"x7.5 +43 fit on a 6th gen?
Old Sep 17, 2004 | 06:51 PM
Nova_Dust's Avatar
Default Will SSR Type C 4x100 15"x7.5 +43 fit on a 6th gen?
SSR website site and Tirerack indicates that 6th gen can only use up to 15"x7. I am wondering if anyone uses 15"x7.5 on their car?
Many thanks
Old Sep 17, 2004 | 07:51 PM
screech's Avatar
Default Re: Will SSR Type C 4x100 15"x7.5 +43 fit on a 6th gen? (Nova_Dust)
havin 16x7 rims on my car (kosei k1's) i had to grind down the rear lca in order to stop the grinding coming from the rear of my car, my rim grindin the lca, durin cornering so my suggestion would be to steer away from the 7.5 in. I would say no bigger than 7
Old Sep 17, 2004 | 08:25 PM
Nova_Dust's Avatar
The inside of the rim will touch rear lca? I am unable to visiualise this. Or you mean the rim was touching the front lca when you turn?
Thanks
Old Sep 17, 2004 | 08:55 PM
screech's Avatar
Default Re: (Nova_Dust)
inside edge would rub against the lca in the rear of my car i have the rim with the damage to it if you want me to post pics i can tomorrow cuz its night now i dont feel like takin pics. if you still cant visualize lmk and ill try to remember to take pics tomorrow
Old Sep 17, 2004 | 09:03 PM
Nova_Dust's Avatar
Cause I thought the lca runs perpendicular to the rims and it goes behind the drum/disc, hence, I don't understand how the rim can touch it.
It is very kind of you to take photos, I appreciate it. No rush, whenever you have time I will look again tomorrow morning and see where it could possibly make contact.
Old Sep 17, 2004 | 09:10 PM
screech's Avatar
Default Re: (screech)
nm im an idiot on me its the uca in the rear that rub. you are right the lca runs perpendicular and there are no clearance problems there sorry for the mis info
Old Sep 17, 2004 | 09:28 PM
Nova_Dust's Avatar
Oh ok, no problem man. I will check it out tomorrow.
The reason I asked was because a local shop told me that some folks are using wider wheels compare to, say, a 15x6.5 sw388. But I want to stay with 15". Currently, I am using a very old Racing Sparco N1 14" rims, 14x6 I believe. But these rims are +37 offset and I don't know how low I can go on them. I got the suspension ready but waiting for next spring cause winter is approaching rather shortly. That's another reason that I might need to go with higher offset rims so in case the drop becomes too severer, at least the metal won't cut the tyre.
Maybe 15x7.5 +43 offset with a 3mm spacer?
jdm94ej1
May 1, 2005 02:08 AM
done
Jan 11, 2005 11:26 AM
LowFlyin'
Jul 10, 2004 06:23 PM
SnlpeR
May 27, 2004 09:56 PM
keithv
Jul 11, 2002 02:58 AM
