will p72 rings fit p73 pistons and what good would it make a dual exaust header
Old Sep 17, 2004 | 06:39 PM
EK FLY's Avatar
Default will p72 rings fit p73 pistons and what good would it make a dual exaust header
hi I I just wanted to know if my stock P72 pistons ring will work with my p73 pistons and if it good to have a dual exuast header going to a two diferent pipes and the to 2 muflers is there any loos of Compression or something ??
here the dual exaust header
Old Sep 17, 2004 | 06:51 PM
chad's Avatar
Moderator
Default Re: will p72 rings fit p73 pistons and what good would it make a dual exaust header (racing_beat)
yes rings wil work
DUAL exhaust=GAY
no performance gains!!!
Old Sep 17, 2004 | 06:58 PM
EK FLY's Avatar
Default Re: will p72 rings fit p73 pistons and what good would it make a dual exaust header (chad)
why is that is the dual exaust help on the exaust gases to flow better
Old Sep 17, 2004 | 07:03 PM
eg_type_r93's Avatar
backpressure
Old Sep 17, 2004 | 07:51 PM
EK FLY's Avatar
Default Re: will p72 rings fit p73 pistons and what good would it make a dual exaust header (eg_type_r93)
would that be loos or gain
Old Sep 17, 2004 | 07:55 PM
inane's Avatar
a loss, you need a certain amount of backpressure... if it flows too freely then there will be a lot less backpressure resulting in a performance loss
Old Sep 17, 2004 | 11:44 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat &raquo;</TD></TR><TR><TD CLASS="quote">why is that is the dual exaust help on the exaust gases to flow better </TD></TR></TABLE>
With only 4 cylinders instead of 8, you need all 4 cylinders paired together to get maximum cylinder scavenging effect to help the engine breathe properly and make decent power. Pairing 2 cylinders only and keeping them seperate all the way back just isn't gonna cut it.
Old Sep 18, 2004 | 07:42 AM
GripFactoR's Avatar
hahahahahaha
.adam.
Nov 21, 2007 02:39 PM
oxSLEEPERxo
Jun 24, 2007 12:11 PM
slowferio714
17
Apr 8, 2007 06:02 AM
dude_123
Sep 29, 2005 08:02 AM
Mr. Vapor
Aug 28, 2005 09:06 PM
