dual valve springs
Old Dec 10, 2001 | 03:14 AM
AfEn808's Avatar
New User
Default dual valve springs
who makes goodvalves springs for a decent price and where could i get some i was thinking of getting skunkworks.
Old Dec 10, 2001 | 03:45 AM
Tbone's Avatar
Default Re: dual valve springs (AfEn808)
It all depends on what cams you are running and or what cams you plan on running. If you have stock cams , changing the springs to stiffer ones will only hurt your performance(unless your going to rev to 9k and then you will need them). Give alittle info on your set up.
Old Dec 10, 2001 | 12:26 PM
evo's Avatar
evo
New User
Default Re: dual valve springs (Tbone)
Why it'll hurt performance, u mean torque or top end power?
Old Dec 10, 2001 | 07:59 PM
AfEn808's Avatar
New User
Default Re: dual valve springs (evo)
the thing is i wanna put type r cams in or something but i only have single valve springs its a first gen b16 head i dont want my valves to start floating at 8k.
Old Dec 10, 2001 | 08:37 PM
Tbone's Avatar
It can hurt performance by causing more drag(friction). Afen, If you are going to be satisfied with just r cams and not upgrade for awhile then just get r springs, but if your going to want to rev above the r revlimt and keep the friction down (compaired to a race spring)then do a itr outer with portflow inner set up, that set up works well. And do titanium retainers while your at it. The itr portflow setup will work with toda a and b spec cams also if you want to upgrade. (you should just buy the head I want to sell you cause it comes with all this stuff)
Old Dec 11, 2001 | 12:51 AM
AfEn808's Avatar
New User
t bone the head you were gonna sell me, wasnt it just a b16 head with gsr cams and a valve job.
Old Dec 11, 2001 | 03:37 AM
Tbone's Avatar
B16 head, 3angle v-job, type r intake valves, rev dual intake and exhaust valve springs(set up for r or skunk cams) a set of titanium retainers, integra type r intake manifold, rc 64mm t-body, str fuel rail, str cam seal, arp head studs and I gave you the option of having it ported if you gave me your stock head.
Old Dec 11, 2001 | 05:11 AM
Phatwhippin_CRX's Avatar
And you want how much $$ for that head?.....
Old Dec 11, 2001 | 09:28 AM
Tbone's Avatar
Default Re: dual valve springs (Phatwhippin_CRX)
1300 for all that stuff + if you give me your stock b16 head also I will send this one for some port work.
teamasr1
Jan 8, 2010 03:03 AM
screaminvtec
13
Jul 23, 2005 10:50 AM
Ditdogs
Mar 17, 2004 06:32 PM
EF'n
Apr 9, 2002 06:59 PM
