I just changed my outer tie rods... quick question
Old Sep 17, 2004 | 03:13 PM
Built B18ABorC's Avatar
Default I just changed my outer tie rods... quick question
I just changed the driverside outer tie rod cuz the ball joint had alot of play. I counted the turns as well as marking the thread with a marker. They are the same as far as length. I also took it around the block to see if it would pull and its driving straight. Do you think I still need an alignment or am I ok?
Old Sep 17, 2004 | 03:33 PM
mr.beeks's Avatar
Default Re: I just changed my outer tie rods... quick question (Built B18ABorC)
you are not OK always align your car after
fixing your front end
but dont forget to fix both sides or the weak side will give up
soon
Old Sep 17, 2004 | 03:45 PM
Default Re: I just changed my outer tie rods... quick question (mr.beeks)
Damn... I guess I'll do that next week. I didnt know I had to change both sides. Thanks for the info. After I get the other tie rod I'll get an alignment. Thanks again!
Old Sep 22, 2004 | 01:10 AM
silversly's Avatar
BANNED
was it difficult to put in the tie rods? and how much did you pay for one? wut brand?
Old Sep 22, 2004 | 01:05 PM
Default Re: I just changed my outer tie rods... quick question (ml2Vo)
It took me like 15 mins to do them. I bought Napa ones for $15.00 each. I'm sure you can get a decent brand name tie rod like MOOG for 30 bucks?
Old Sep 22, 2004 | 06:55 PM
sabotage7's Avatar
i did that same thing too, counting the threads when i took my tie rod off, and i got it aligned anyways cuz i have lifetime alignment and they said it was fine but you should always get an alignment after doing that sorta thing!.....paying for lifetime alignments is sooo worth the money!
Edul59
Suspension & Brakes
Nov 11, 2008 08:17 AM
VTECIntegra9
Suspension & Brakes
Aug 14, 2008 02:02 PM
DeDonDeRosa
Mar 1, 2007 11:59 AM
drumminforev
Apr 10, 2006 01:42 PM
Boosted Chemist
Jun 14, 2004 03:19 AM
