d16 cam
Old Sep 17, 2004 | 01:32 PM
Civichatch27's Avatar
Default d16 cam
Am i better off putting my old d15b2 head back on with the d16 cam. Or just keep the d16(non vtec) head? Can i expect any power gains?
Reason why i ask about the d16 cam is becuase i read that the d15 and d16(non vtec) heads are the same, execpt that the d16 has a "wilder" cam. is this true?
Old Sep 17, 2004 | 02:09 PM
dr_latino999's Avatar
Default Re: d16 cam (Civichatch27)
Yup cam is different, but if you have the original valvetrain, the SI springs and all will be stiffer. Also, to put in the A6 cam you will need the cam gear, preferably adjustable due to a difference in overall height I hear.
Old Sep 17, 2004 | 02:30 PM
Default Re: d16 cam (dr_latino999)
So should i use the d15 head with the d16 cam or just change the head to the d16?
Old Sep 17, 2004 | 02:37 PM
quicksol95's Avatar
change the head
Old Sep 17, 2004 | 02:46 PM
Default Re: d16 cam (slowsohccivic)
what kind of power gains should i expect, if any at all. the head came off a 98 civic, i buy the 98 head gasket right?
Old Sep 17, 2004 | 02:52 PM
quicksol95's Avatar
if its the y7 head and you use a y8 headgasket you should see around 10.1:1 compression and get a little hp from the motor
Old Sep 17, 2004 | 02:55 PM
Wait, I don't even think an A6 cam would fit in a Y7 head.
Old Sep 17, 2004 | 03:02 PM
well if thats the case ill use the whole head. Now, im not familiar with the y7 y8 terminology,all i know is that the head came off a 98 non vtec civic. What year and type are the y7 and y8? And how can i tell by looking at my head what kind I have?
Old Sep 17, 2004 | 03:10 PM
If it came off a 98 Non-VTEC, then it is a Y7. A Y8 is the 96-2000 EX
Old Sep 17, 2004 | 03:12 PM
all right cool, so i should use a 98-2000 ex head gasket. Anything else i should know?
91 EF DX
May 24, 2013 07:34 PM
WinstonSmith
Oct 14, 2012 04:49 PM
ef-hatchcrap
Mar 3, 2009 05:50 PM
walmartcivic
Nov 5, 2007 12:31 PM
